89 4runner,22re, AC pulley and PS pulley the same?
Old 01-02-2011, 07:23 AM
Junkers88's Avatar
As the title says is the AC pulley and the PS pulley the same? I'm talking about the little ones that are used to tension the belts. I ask because last night after some accidental off-road fun, and the ensuing things done to get out of the ditch, my PS tensioner-pulley-thing locked up. I'd like to swap out the one from the AC if I can so I can drive it down to the pick-n-pull place tomorrow and get a used one instead of trying to find/paying a pile for a new one.
Thanks much and please be careful in the snow and ice.
Old 01-02-2011, 07:28 AM
kiyobrown's Avatar
Pretty sure they are different. The AC idler pulley is sold at auto stores as a whole unit. The power steering pulley you just replace the bearing inside of it. Can't remember the number off hand, but it ends with ff. I don't see why you wouldn't be able to swap em to get to the store and back, or just run without power steering altogether for a couple miles.
The bearing to replace in the ps idler pulley was a sealed unit, and wasn't much more then $20. Now if you lost the pulley altogether, dealer wanted upwards of $300 for a new idler pulley.
Hope all is well, Ricky!!
Old 01-02-2011, 08:53 AM
wyoming9's Avatar
Red face
Now that is interesting I only paid about $9.00 for mine at local bearing supply
Part # NKE 6204 RS2
You could get it at any bearing supplier
Looking on McMaster-Carr a premium bearing was less then $20.00
Old 01-02-2011, 10:04 AM
se7enine's Avatar
I paid nothing and rebuilt bearings myself.
Old 01-02-2011, 10:42 AM
kiyobrown's Avatar
Old 01-02-2011, 10:57 AM
BigBluePile's Avatar
No dude, the bolt holes are different.
Yup, paid $9 for the bearing from Advance Auto when my idler bearing siezed up on the interstate in a big ball of smoke...which with the louvers I have on the hood it was like smokin dragon nostrils.
Dont be a baby, so you have to drive around with manual steering, it isn't gonna hurt anything...just make your arms all swole up for the ladies!
Old 01-02-2011, 01:34 PM
Junkers88's Avatar
Thanks folks.
Any tips for getting the bearing out of the damn pulley? I'm looking at it and it appears that I'll need a press to get the old one out and the new one in.
Old 01-02-2011, 03:15 PM
PirateMcgee's Avatar
I got mine out by setting my vice slightly wider than the bearing but smaller than the pulley, laid it on top with beaing over the gap, and then used a hammer and a big punch to knock out the bearing
Old 01-02-2011, 03:42 PM
kiyobrown's Avatar
Yup. About the same. Got an impact socket that fit in the hole and tapped a rubber mallet on it til it popped out.
Old 01-02-2011, 03:44 PM
camo31_10.50's Avatar
i swapped mine on my '86 (AC didn't work any way) and it worked prefectly fine.
Old 01-02-2011, 04:55 PM
Yuppers
I don't think so scooter.
Old 01-03-2011, 10:52 AM
Junkers88's Avatar
Well that was a PITA. 4 auto parts places (won't even go into having to request a counter person that speaks English) later and I got the bearing. Now I've got power steering again but the freaking pump is making an odd noise that I never noticed before....... dang it just never seems to end.
Old 01-03-2011, 11:09 AM
rattlewagon's Avatar
I have my AC pulley on my PS spot right now. Been that way for about 2 months now. All seems to be holding up fine. My belt alignment still isn't quite right, but not worried about it that much.
The AC one was a bit smaller, so my adjustment is maxed out.
Old 01-03-2011, 11:12 AM
Junkers88's Avatar
I actually pulled my AC idler just to see if it would swap and if I swap the mounting bolt also then it'll work. Now I know I have a spare if I need it.
mskalmus
05-28-2017 07:51 AM
MMA_Alex
25
04-18-2017 05:07 AM
bryan34w
07-06-2015 05:53 PM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 89 4runner,22re, AC pulley and PS pulley the same?
