89 3.0 no heat
Old 03-27-2011, 01:33 PM
jrn2786's Avatar
89 3.0 no heat
Ok this is my first post here. Anyway thermostat is new. Had blockage in heater hoses, I cleared all the hose and the heater core is flowing. I let it run for a while with cap off to get any air bubbles out Truck seems to run at normal temp. my next guess would be water pump. But wouldn't there be other symptoms? Thanks
Old 03-27-2011, 04:24 PM
jrn2786's Avatar
Could a bad rad. cap make the heat not work and motor not warm up all the way? gauge only goes up about 1/3 of the way. I bled the crap out of the system with front elevated so no air pockets
Old 03-30-2011, 05:00 PM
jstluise's Avatar
A bad Tstat (stuck open) will not allow the engine to get up to operating temperature. That is the first place I would look.
Old 03-30-2011, 05:10 PM
jrn2786's Avatar
I figured it out. Had another clog where it goes to the auxiliary idle. Good to go now
Kreedy1
09-08-2015 06:33 PM
viesail
08-17-2015 08:39 PM
jjrbus
07-19-2015 02:06 PM
tobylab
07-12-2015 12:53 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 89 3.0 no heat
