89 3.0 4X4 auto trans, no drive. Help!
It's gradual but pretty abrupt (if that makes sense). The vehicle runs fine, shifts through all gears for about a mile or so then will start to slip. After coming to a full stop, it will no longer move forward on its own. Reverse usually works but after some time that will go away also.
I can't help you much with auto transmissions. Check out the FSM link that was just posted. Hopefully that will help.
It is a tricky one because the tcase has a separate oil pump, don't want to give any one false hope, possibly could be an issue with that pump and or pick up for that pump
