89 22re engine trouble
Old 03-01-2009, 04:31 PM
4x4cody's Avatar
Cool 89 22re engine trouble
well ... i knew something was wrong so i took it in to a shop
when they got done they said i have 90lbs compression in one cylinder and iam suppose to have 140 right? well all other cylinders are good but for one
replaced wires,plugs,cap but could it be my valves?
when i first bought it i took it in for tune up and they tightened my valves.
but thats been 5 months if not more .. did they maybe tighten them too much and i have a burnt valve??
please tell me your input.. i need this running good asap its my daily. thanks
Old 03-01-2009, 04:34 PM
abecedarian's Avatar
burnt valve could cause a low compression reading.
I'd have a leakdown test done if possible. That will narrow down things to at least burnt (or maladjusted) valves, rings and/or headgasket issues.
Old 03-01-2009, 04:35 PM
and if the weak cylinder was the last one tested, I'd tell them to charge the battery and test again.
Old 03-01-2009, 04:38 PM
4x4cody's Avatar
thanks man.. i'll look into that ...
Old 03-01-2009, 05:06 PM
4x4cody's Avatar
anybody else ?
Old 03-01-2009, 05:43 PM
Targetnut's Avatar
compression test only tells you part of the story.
Now you need to do a leakdown test to pinpoint the leakage.
A tight valve could cause that low reading. as could rings.
If the headgasket were the culprit, you wouldn't be posting as you would be blowing coolant out as fast as you could put it in.
If it is leaking past the valves the first thing to do would be to check the valve clearances
Colington
03-08-2020 09:51 AM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
Avenged
07-09-2015 07:55 AM
cyclist231
07-07-2015 12:56 PM
Quick Reply: 89 22re engine trouble
