89 22re 4runner died and started
Old 03-31-2008, 02:27 PM
eightnine's Avatar
Hey everyone, my truck died on the side of the road today while i was driving very slowly (probably around 20km/h). It just stalled and wouldnt start. It would crank but nothing. I ended up calling a tow truck after trying to start it for 20 minutes and brought it to my mechanic. Once the truck got there it started up no problem?! Anyone ever experience this before? Im worried now because i dont know if it will die on me again in the future with no warning. I think it might be the alarm system that i have because it stops the fuel pump from working when someone tries to steal it.
Old 03-31-2008, 04:22 PM
eightnine's Avatar
bumpp
Old 03-31-2008, 04:24 PM
scuba's Avatar
if thats what you think
you could have a short
Old 03-31-2008, 04:45 PM
eightnine's Avatar
I'm not sure though, its just a thought..
Old 03-31-2008, 07:01 PM
eightnine's Avatar
any other ideas?
Old 04-01-2008, 05:43 AM
eightnine's Avatar
bumpp
Old 04-01-2008, 05:50 AM
mr_schuster's Avatar
Possible coil or ignitor. My Camry, use do do that crap when it was hot. It needed a coil. ???
Old 04-01-2008, 06:08 AM
NwRunner's Avatar
i had the same problem with my Honda, died on the freeway at 60MPH.... i let it sit and it started 10 minutes later. Replace the Coil.
Old 04-01-2008, 06:34 AM
eightnine's Avatar
I think its a fuel related problem because it felt like the gas ran out as it studdered a bit. Then when i tried to start it again it felt like it didnt have enough gas. Third time i tried it just cranked but nothing.
Old 08-21-2008, 08:55 PM
fireman1559's Avatar
hey im having the same problem except my truck didnt start back up. did you ever get it fixed?
Old 08-21-2008, 09:01 PM
4Crawler's Avatar
My '85 did that once about 10 years ago after spending a week and a half in a shop. Drove about 30 minutes and everything just cut out. Pulled over and checked every fuse (pulled them out to visually and electrically test each one). Found nothing wrong and then tried the starter and it fired back up and has not done that again. I suspect it was some oxidation on one of the fuses or the fuse block and just pulling and replacing them may have cleaned the connections enough to return to normal.
Old 08-23-2008, 01:46 AM
4wheeler808's Avatar
CHECK THE EFI MAIN REALY AND CONNECTING RELAY AND ALL THE CONNECTORS LEADING TO THE FUEL PUMP........
IT HAPPEN TO ME BEFORE..........THE THING JUST DIE OUT WHILE I'M DRIVING.........LATER ON AFTER DIAGNOSING..........I FOUND OUT THE CONNECTOR UNDERNEATH THE CARPET BY THE PASSENGER SIDE...THE FUEL PUMP WIRE(its blue with red stripes on it) is loose...........
i just went clean and repair........no more problem after that............
91toybeater
12-27-2015 07:46 PM
puffin04
07-10-2015 09:17 PM
camdenbuck
07-07-2015 07:33 AM
ibayne
06-26-2015 06:30 AM
slider417
06-22-2015 10:18 AM
Quick Reply: 89 22re 4runner died and started
