'88 Rear bump stop length
Old 02-21-2011, 11:59 AM
prolite1's Avatar
Does anybody on here know the length of the stock rear bump stops on an '88 pickup? Cut mine a while back to try out the Zuk mod and have since decided to go a different route. Now I need to fab some up. Thanks!
Old 02-22-2011, 08:40 AM
prolite1's Avatar
Can someone run out to the truck and measure? Pretty please...
Old 02-22-2011, 09:51 AM
corax's Avatar
Do you need the rubber bumpstop or the part on the frame that it contacts?
If it's just the rubber part, order up a set of the 9.9109 bumpstops
Old 02-22-2011, 09:54 AM
prolite1's Avatar
The metal part on the frame that it contacts.
Old 02-22-2011, 10:03 AM
xxxtreme22r's Avatar
on my 87: 3 1/2" from frame to the bottom of the stop. Should be the same for your 88.
I do need a favor from you though, what is the measurement of the bottom bump stop? Mine are missing.
Old 02-22-2011, 10:04 AM
corax's Avatar
3.5" overall height from the frame to the part the bumpstop contacts & the contact pad is about 3" square
Old 02-22-2011, 10:22 AM
prolite1's Avatar
Perfect, thanks guys!
Old 02-22-2011, 10:24 AM
prolite1's Avatar
Bottom bump stop is also 3 1/2
Old 02-22-2011, 10:25 AM
that's what I thought, just wanted to be sure. Thanks.
Old 02-22-2011, 12:03 PM
not sure if you want to go this route or not, but figured I'd post it up since I was searching for bushings etc etc
48344-35020 STOPPER, BUMPER, REAR 1983.08-1989.03 LN6#, RN6#, VZN6# $31.81
http://www.toyotapartszone.com/Page_...onentsIndex=55
the1998sr5
15
07-14-2020 08:35 PM
05-20-2016 10:27 AM
Yotadawgjr
10
08-23-2015 10:51 AM
icentropy
07-11-2015 07:21 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: '88 Rear bump stop length
