88 pickup dash lights not working
Old 03-31-2010, 08:07 PM
88redyota4x4's Avatar
Exclamation 88 pickup dash lights not working
on my 88 pickup, the temp-spedo-and fuel gauge lights are not working in the gauge cluster, but all the other lights in the cluster are working, any ideas what could be wrong, already checked all the fuses there good, and the dimmer switch is turned up all the way to, any tips would help, i don't think the bulbs are burned out in it, but i could be wrong, thanks
Old 03-31-2010, 08:58 PM
Rooke1991's Avatar
same problem with my 89. so help us out!
Old 03-31-2010, 09:49 PM
Western Canuk's Avatar
are your marker lights working?
on mine the markers and dash lights are the same fuse. Check it.
When it happened to me I replaced the fuse and pop again right way. Turned out there was a short on the front left marker wiring but really there could be a short anywhere in the marker light circut.
edit - I see you said you checked the fuses already. Try replacing it with another one just to be sure
Old 04-01-2010, 09:05 AM
update: ok took the dash apart and the cluster, and all the bulbs are fine, but on the contacts where the 2 bulbs sit for the spedo and fuel gauge and temp, the contacts look a little worn, could this be the problem, and i double checked all the fuses again and there fine, and the marker lights work, am i just gonna have to get a whole new cluster
Old 04-02-2010, 01:59 PM
update guys, the two bulbs were blown that light the 3 gauges, i couldn't tell it because the green condom like coating on the 2 bulbs, haha, thanks for the help guys
Aleeex_u
06-05-2016 06:52 PM
Valvoman
06-28-2015 02:45 PM
gog1968
06-22-2015 05:55 AM
Taz22R
06-21-2015 04:44 PM
ShaunKris
06-17-2015 04:33 PM
Quick Reply: 88 pickup dash lights not working
