88 4Runner - Heater Core Change?
Old 06-28-2008, 04:56 PM
Toyotero's Avatar
The 88 FSM and 85 FSM don't seem to have the process to change a leaking heater core (under the dash, not the console)... any recommendations?
Old 06-28-2008, 07:08 PM
InternetRoadkill's Avatar
You have to remove the entire dash.
Old 06-29-2008, 01:10 PM
myyota's Avatar
Ive done heater cores in two different trucks, it takes about four hours from start to finish. Its not as hard as it looks, just very time consuming.
Old 06-29-2008, 01:25 PM
Staff
DeathCougar's Avatar
If you have AC you will need to have it discharged/charged in accordance with Federal law. Its a hefty fine if you discharge it into the air and someone reports you.
Old 06-29-2008, 05:09 PM
Toyotero's Avatar
Heater core dude, not evaporator.
... and if I had a leaky evaporator, then the refrigerant recovery problem would have taken care of itself :-P
Thanks for the replies.... I was hoping someone might have a pdf of the process from a manual or something...
Old 06-29-2008, 06:07 PM
Staff
I realize we are talking about the heater core. Dude. But in order to remove the heater core, you have to remove the Evap box. Dude. And that means you have to drain the AC. Dude. Which is why I said IF you have AC.
Dont ask for advice then question the very answers the guys who know about it give you.
Dude.
ashersullivan88yota
01-18-2022 05:37 PM
icentropy
09-16-2020 02:47 PM
smiley52
07-11-2015 05:16 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 88 4Runner - Heater Core Change?
