'88 4runner Diagnostics pulling codes
Old 09-28-2008, 07:39 AM
'884Runner's Avatar
The check engine light has been coming on in the 4runner intermittently, usually at start up. I have been trying to figure out how to pull the codes using 4Crawler's cheap tricks page. The 4runner has the Later model FP-B+ Jumper. I inserted a gym clip in each port and turned the ignition to on, engine not running, and loe and behold... nothing happened. What am I doing wrong?
BTW, don't know if it makes any difference, 22R-E, 5-Speed
Old 09-28-2008, 07:54 AM
88T4R's Avatar
Are you putting the paper clip in the t1 and E ports?
Old 09-28-2008, 08:20 AM
'884Runner's Avatar
Mine doesn't have those ports labeled. I have a E1 and T port. I'll take a stab at making a diagram.
From the top
0 0 Ect
0 E2 Tem
0x 0
E1 0 0
0 T Vf
Fp Cco +B
0 represents blanks ports.
What I tried doing was inserting the gym clip into the Fp and +B ports, which are located closest to the passenger side fender. I'm not sure if those are the correct ports or not.
Old 09-28-2008, 08:30 AM
4Crawler's Avatar
From the top
0 0 Ect
0 E2 Tem
0x 0
E1 0 0
0 T Vf
Fp Cco +B
Jumpering Fp and B+ is the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
You likely want T and E1 to get the diagnostics mode:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old 09-28-2008, 08:40 AM
'884Runner's Avatar
Thank you, I tried it again and got codes 21 and 51... I'm about to check into these now.
Michael
Old 09-28-2008, 08:52 AM
'884Runner's Avatar
O.K., code 21 should be a simple fix, but code 51 could have a couple of causes. Also, I am not sure that I actually understand what the TPS does. It also mentions A/C circuits... The air conditioning does not work, but I assumed that it is just low freon. What is the most probable cause of this code? Thanks.
Old 09-28-2008, 09:05 AM
pepsibluefloat's Avatar
adjust the TPS before replacing it.
page 4-13 in the Haynes manual. requires feeler gauges and volt meter.
Old 09-28-2008, 09:35 AM
'884Runner's Avatar
Is it likely that the two are related? Could the oxygen sensor be causing the code 51 also? Or are these two most likely two seperate problems?
Thanks,
Michael
Old 09-28-2008, 09:52 AM
4Crawler's Avatar
Thanks,
Michael
Look at the common causes in the table on the linked web page. Not likely that one could cause the other, check each out separately.
Old 11-15-2011, 08:48 AM
SDTrucking's Avatar
go here and it will show you how to pull the codes http://www.ncttora.com/fsm/index.html
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: '88 4runner Diagnostics pulling codes
