'88 4Runner 4x4 v6 Starter Replacement?
Old 05-06-2008, 10:54 PM
B-b0y's Avatar
Hey guys, bought my starter today and wanna get it swapped out tomorrow. Does anyone have a Do It Yourself link with all the tools I'll need and easiest way to replace it? I did a search but can't find anything for an '88. Any help would be GREATLY appreciated. Cheers...
Old 05-06-2008, 11:28 PM
nv4runner's Avatar
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Not sure on the tools but it should be pretty easy. I've got a 92 4runner, so this may not apply to you (depends on 1st gen or 2nd), with a removable panel that is bolted on above the upper control arm of the passenger side wheel well. This gives you easier access to the starter. Removing the wheel also helps.
Luckily I haven't had to replace or even remove my starter. I just did some tests on it for class and found out that the starter control circuit on these is a very efficient design with very little voltage drop.
Old 05-07-2008, 02:54 AM
redheaded step truck's Avatar
14 mm 12 mm 10mm and some fussing & cussing
this should be all u need
Old 05-07-2008, 05:49 PM
mtnfreak's Avatar
Try these links (same thing, different look):
https://www.yotatech.com/forums/f128...4runner-76358/
https://www.yotatech.com/~corey/tech...imrockford.htm
mskalmus
05-28-2017 07:51 AM
izzmee
08-17-2015 10:20 AM
Dakotaneu
08-15-2015 07:24 AM
rustym
08-07-2015 10:39 AM
defrag4
07-31-2015 10:50 AM
Quick Reply: '88 4Runner 4x4 v6 Starter Replacement?
