88 3vze pickup starts then dies
Old 07-01-2015, 08:15 PM
MadMax48's Avatar
Truck has out smarted me. It stars when cold then runs perfect for a while and then dies and starts to chug. Sometimes starts after and runs like ˟˟˟˟ sometimes doesn't restart. Ect has been replaced, fuel filter and pressure regulator have also been replaced. All new ignition components plugs wires cap rotor and msd coil. has spark and has fuel pressure at the regulator. I'm stuck and I need help.
Old 07-02-2015, 06:56 AM
scope103's Avatar
The "classic" starts-then-dies is a problem in the COR-VAF system (though usually it starts fine, runs for just a few seconds, then dies from fuel starvation).
Fortunately, as complex as the problem might be, it is the easiest thing on the truck to diagnose. Jumper B+ to FP on the diagnostic connector (this forces the fuel pump to run with key-on). If the problem goes away, you found where it is.
Don't just drive around with the jumper in, as tempting as that might be. If you get in an accident that breaks a fuel line, you really want that pump to shut off pronto.
Old 07-02-2015, 08:19 AM
MadMax48's Avatar
Pump is already in a toggle... So it doesn't shut off... I think I had the problem you are speaking of but it takes like 20 minutes to a half hour to shut off not a few seconds
Old 07-02-2015, 08:45 AM
scope103's Avatar
Originally Posted by scope103
... Don't just drive around with the jumper in, as tempting as that might be. If you get in an accident that breaks a fuel line, you really want that pump to shut off pronto.
Uh, do you really want to end up like your "name sake"? It's your life, but I suggest you give it some thought.
Old 07-02-2015, 09:52 AM
MadMax48's Avatar
Is was a last minute thing just to get it going. That's not the goal here. I make bad life decisions I don't care I just need to get my truck running
Old 07-03-2015, 12:55 AM
wyoming9's Avatar
Red face
Have you narrowed things down to it being a fuel or electrical problem??
Have you tested fuel pressure when it dies on you?? Just what brand fuel pump There is a bunch of poor quality ones out there.
You replaced all the ignition parts new igniter as well Sure sounds like something is getting hot after 20 minutes
Electrical system in good shape a under voltage system will shut down.
Engine will always start when things are cold??
Old 07-03-2015, 06:44 AM
MadMax48's Avatar
I still have spark and I still have fuel pressure at the regulator. Fuel pump is original as far as I know. I never replaced it. But it does work. Ignitor was not replaced. I'm leaning twords injectors so I started replacing them yesterday. Pulled a set out of the yard and we'll see how they go back together. Worst case it's coming out and getting a swap.
Old 07-03-2015, 06:45 AM
MadMax48's Avatar
But yes it always starts when cold. And the voltage isn't going down. It holds 14.5 the whole time.
Old 07-03-2015, 08:26 AM
wyoming9's Avatar
Red face
Just what does the fuel pressure read in pounds per square inch.
If it drops off the injectors will not open.
zd92655
03-06-2022 12:58 PM
Dillon1983
07-07-2015 06:47 PM
Alex Bessinger
06-28-2015 10:05 AM
ibayne
06-26-2015 06:30 AM
ChrisJ
30
11-29-2009 11:13 AM
Quick Reply: 88 3vze pickup starts then dies
