88 22re Issues
88 22re Issues
I bought somebody else's project that needed an engine and have a timing issue after the swap. It sounds the same(tries to start) regardless if the ecm is plugged up or not and the check engine light comes on when the switch is off(with the ecm plugged up).
need more info.
cel is on with the key off?
what sort of swap?
the ignitor will generate spark while cranking even if the ecu may be failing- that's how it works. once the engine is running the ecu takes over timing control.
so you're not giving enough 411 to troble shoot.
what sort of swap?
montanatruck
02-26-2017 07:07 AM
