874runner-94pickup
Old 08-19-2009, 05:47 PM
krawnic's Avatar
874runner-94pickup
Hey guys, new here, and to the toyota scene. I bought a 94 pickup extended cab about a month ago, bone stock, my original plan was to SAS as cheaply as possible. My buddy has a 87 4runner with in IFS lift and 33s, but he blew the motor, so im thinking of snagging it from him. So my plan is to now buy the 4runner and swap that lift over to my pickup, and then ill start piecing together parts to sas the 4runner. What do you guys think? Will the parts swap over directly? Is it worth it?
Old 08-19-2009, 05:56 PM
abecedarian's Avatar
The front end of the lift should cross over from the 87 to the 94 perfectly fine.
If the 87 4Runner used new leafs for the rear lift, they will probably not be the correct length for the 94 truck... but if the lift on the 87 4Runner used blocks, the blocks should work... but you might need u-bolts.
