YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 01-14-2009, 08:35 AM   #1 (permalink)
Personal Sales Rating: (0)
87 Truck 22r Chugs in 5th gear over 50mph
My Toyota truck 22r 1987, in 5th gear it chugs like it doesn't have enough fuel. I will be on the highway and if i lightly (and i mean lightly) press on the accelerator it will accelerate to about 65-70 and thats it. It won't go past that. If i try to go past that THE ENGINE CHUGS AND IT SEEMS LIKE THE POWER CUTS IN AND OUT. I replaced the fuel pump and air filter. What else should i do?
Baltic100 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-14-2009, 08:42 AM   #2 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
typical setup... lol. how do u think these engines are so reliable? theyre overbuilt and underpowered.
__________________
2001 Ford F-150 6" lift 315x85x16 tires. (37x13.50s???)
4.6L V8
bumping stereo I love it
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
the toyota is gone... its been fun..
ozziesironmanoffroad is offline
Old 01-14-2009, 08:46 AM   #3 (permalink)
give it a tune up...new plugs, wires, fuel filter, air filter, cap, rotor.
clean out your maf sensor, make sure your timing is right.
mine would do the same thing when i first got it, felt like it had no power if i went more than half throttle, i just gave it a little more timing and it runs like a champ now.
fivesfe is offline
Old 01-14-2009, 10:06 AM   #4 (permalink)
Threadstarter [OP]
How do you give the truck more timing or even change the timing? Where is the MAF sensor, and what is the best way to clean it.
Old 01-14-2009, 11:07 AM   #5 (permalink)
The 22R has a carburetor and does not have an air flow sensor--that's for efi engines.
Timing is adjusted by using a timing light and rotating the distributor to bring timing into spec. Check the sticky for online fsm -- there is on for 85 trucks which will cover the ignition system for 22R engines. Make sure that when you set timing that the engine is at the proper rpm. The 22R distributors have mechanical advance which is speed sensitive.
Your problem is likely either tune-up related or faulty fuel delivery related. Do what fivesfe suggests for a start. Might also consider adjusting the valves, checking compression, etc. Make sure you have no vacuum leaks. Might also take a look at the carb to make sure you're float's properly set, that it's free of contamination, etc. Can't say for sure in your case, but sometimes slow fuel delivery and dirty carbs can cause the symptoms you report.
desconhecido is offline
Old 01-15-2009, 08:48 PM   #6 (permalink)
Threadstarter [OP]
solution to the PROBLEM
You were right, I just worked on the truck today. I changed the Plugs, cap, router, wires, and fuel filter. The Truck runs like NEW. I swear there is a massive amount of restored horsepower. Its amazing the difference. It no longer chugs above 50 MPH. thanks for your help.
Yotatech
4WD Truck
Paid Advertisement
Tags
1987, 22r, 50mph, 5th, 87, air, check, chugging, chugs, clean, flow, fuel, gear, mass, pump, sensor, toyota, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Trans will not go into 5th gear georgiayota Pre 84 Trucks 3 09-24-2008 04:39 PM
01 Tacoma V6 slips out of 5th gear Stal 95.5-2004 Tacomas & 96-2002 4Runners 3 07-17-2008 08:10 PM
No 5th gear 87 yota 86-95 Trucks & 4Runners 15 05-31-2008 09:32 AM
Can't get into 5th gear Biohazard Off Topic Talk 1 09-28-2006 02:24 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
