87 toyota pickup running rough
Old 05-19-2014, 09:22 AM
isonja's Avatar
I recently bought an 87 5 speed 22r 4x4 solid front axle. The truck sat for a about a year before i bought it and its running rough. I changed the oil and filter. Truck is idling high and smokes when given throttle. it doesnt have nearly the amount of power that it should. I put some seafoam in the gas and it helped the truck run smoother but not much better. Where should I start?
Old 05-19-2014, 09:43 AM
InToxicOne's Avatar
Well what type of smoke are you seeing out the tail pipe? If its running rough there are a number of things to look at. Does it go away when you go to higher rpms or does it get worse? Does it stumble at all before you get it rolling? Did the carb have fuel in it when it sat? Check your plugs and wires. Check everything you can easily get to. Air filter ect.
Old 05-19-2014, 09:57 AM
scope103's Avatar
Very generally, engine smoke is white (due to coolant in the exhaust), blue (oil), or black (unburned hydrocarbons, usually meaning an over-rich condition).
Can you classify the smoke by this sort of color scheme?
Old 05-19-2014, 10:25 AM
isonja's Avatar
the smoke is white and gets worse the higher you rev. It idles high but will run all day, then lags when you give it gas and let the clutch out. no air filter on the truck at the moment
Old 05-19-2014, 06:24 PM
InToxicOne's Avatar
Well check your plugs. If you see white or perfectly clean plugs then most likely you have a bad head gasket. If the plugs are clean but there is still smoke then you may have a crack in your head where the water jacket runs past the exhaust valves.
Old 05-20-2014, 05:28 AM
isonja's Avatar
once you get moving it runs better. no coolant in the oil, oil is not milky or anything like that
Old 05-21-2014, 07:28 PM
InToxicOne's Avatar
So once it warms up the problem is less noticeable? If it gets higher when you rev but isnt in your oil its a good possibility that your combustion is converting the coolant into steam before you get blow by into your oil sump. That's why I say check your plugs. A head gasket leak does not always mean oil and water will mix.
Old 05-21-2014, 07:52 PM
yotayes88's Avatar
Replace plugs, wires, cap, and the rotor. After that let it run for. a bit. ill bet its nothing serious, since it sat for a year. just run it. ill bet you it gets better. no joke
Old 05-23-2014, 05:14 AM
isonja's Avatar
It feels like it has lack of power. sometimes in 3rd and 4th i have to pin it to get up hills
Old 05-23-2014, 06:28 AM
HighLux's Avatar
You said no oil in coolant or coolant in oil.
BUT
you never mentioned if it is loosing coolant or coolant level is low.
Sometimes its about what is not asked.
Old 05-23-2014, 07:53 AM
isonja's Avatar
no oil in coolant or coolant in oil and its not losing coolant or oil
Weidle
01-21-2019 05:39 AM
Crazychris1871
06-27-2016 10:38 AM
puffin04
07-10-2015 09:17 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
94hiluxZE
06-22-2015 10:42 AM
Quick Reply: 87 toyota pickup running rough
