87 manual trany question
Old 07-16-2007, 07:49 PM
co4rnr's Avatar
Hi all, over the weekend I pulled my engine from my 87 4runner with the 22re. I tried to take the motor out with the bell housing and trany attached. After figuring out that the trany is alot longer than I thought, I pulled only the motor out. First, I tried to unbolt the trany where I thought it ended. I think that the trany is built in two pieces? I put the bolts back in the place where I took it apart and now it leaks. Is there a gasket in that spot, or is it even possible to separate the two pieces of the trany?
Old 07-16-2007, 10:48 PM
just a 22re's Avatar
where did you pull it apart the bell housing or the transfercase? just asking to get more info on this
Old 07-17-2007, 03:47 AM
co4rnr's Avatar
I took it out by unbolting the engine from the bell housing.
Old 07-17-2007, 04:25 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
You took it apart at the transfer adapter. So, you'll need to reseal it.
This is a diagram of the whole unit:
http://personal.utulsa.edu/~nathan-b...30assembly.pdf
But, more descriptions are here:
"W55 & W56"
http://personal.utulsa.edu/~nathan-b...nualtrans.html
Old 07-17-2007, 05:09 AM
co4rnr's Avatar
Wow, thanks, that helps out alot. Is is possible to unbolt the t-case adapter from the trany, or is there gears inside holding it together.
Old 07-17-2007, 05:47 AM
thook's Avatar
The links I posted will show you what you're asking.
colasurdo
05-14-2022 07:21 AM
delmert
09-30-2015 04:34 PM
TransAmBandit
07-28-2015 11:30 PM
TURBOrunnerNM
07-22-2015 11:01 AM
rushw
07-18-2015 01:46 PM
Quick Reply: 87 manual trany question
