87 automatic 4unner transmission problem
Old 01-24-2010, 08:32 AM
Unique's Avatar
I have a 1987 automatic EFI 4x4 Toyota 4unner.
Most of the time when I take off at a stop light, it works perfectly.
But sometimes when I take off, it accelerates very slowly and the over drive light next to the radio flashes on and off. When I get to about 30 - 40 MPH, it starts accelerating correctly again.
What's wrong with my truck?
Old 01-24-2010, 10:45 AM
wrnchplr's Avatar
search on this issue, there is lots of info on it.
It's caused by the shift solenoid. when the computer detects an issue it defaults into a (limp home) mode. thats were it defalts into 3rd gear. if you shift the trans manualey it should shift fine. I've been having the same issues with mine. I pulled the pan and cleaned everything out, tested and cleaned the solenoids, reinstalled with fresh oil and filter. works fine now.
BeMiceElf
10-10-2015 09:40 PM
Poncho0206
07-10-2015 06:21 PM
shar
07-09-2015 12:38 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: 87 automatic 4unner transmission problem
