87 4runner- clutch, MC, etc problem?
Old 02-20-2010, 01:47 PM
JShaffer0525's Avatar
The vehicle- 1987 4runner w/ 22re, w56 manual transmission
The issue- I was pulling my friend out a some snow the other day and all of a sudden my 4runner won't move (like the clutch won't engage).
Things that may help diagnose my problem-
-still have to have the clutch pedal in to start the 4runner and move through the gears (hopefully not transmission?)
-when the clutch pedal is released it idles slightly lower when in gear as if it were going to die like it would if you let the clutch out without giving it gas. it feels like a tiny remnant of the clutch wants to engage still but it cant.
-everything around the pedal bracket appears to be fine,, tight, not broken
-the master cylinder has been leaking maybe 1 cup full per month, enough to notice fluid on my floor and around where it comes through the firewall.
-there is still a lot of pressure behind the pedal, it is not slack at all
-the clutch is a basic clutch from advance or auto zone, nothing special. it was replaced when i did my engine swap less than 10k mi ago.
-i have been using my 4runner to pull people out of snow and stuff but nothing that i feel strains it in anyway. the clutch has not shown any signs of slipping before it stopped engaging.
-there is no boot at all around the clutch fork (that is what is going into the right side of the transmission right?)
-i tried adjusting the nut that connects the clutch pedal to the master cylinder. there was no change at all.
I should clarify- I guess I'm asking if it is indeed my clutch or not? If not, what do you think it is?
I have searched through threads on clutch installs and clutch bracket issues and such but I haven't seen anything that pertains to me. I am a novice at this but I don't mind getting my hands dirty and I welcome all your input.
Thanks!
For laughs I called around to get prices on replacing the clutch (though I intend to do the work myself) and the dealership quoted me at over $700! HHAAHAH
Last edited by JShaffer0525; 02-21-2010 at 10:15 AM. Reason: clarification of issue
Old 02-20-2010, 02:45 PM
pruney81's Avatar
when mine went a while back a bought an OEM Aisin kit from http://www.wabfab.org/products/clutches/clutches.htm and had my flywheel resurfaced locally. I'm lucky a friend helped me put mine in for $180.
Old 02-20-2010, 04:19 PM
thats the thing, im not entirely sure mine is gone. it showed no signs of wear until it just completely stopped working which im hoping/guessing could be caused by something else. if it is indeed the clutch then ill be dropping a 1600lb MC clutch in it.
Old 02-20-2010, 04:29 PM
waskillywabbit's Avatar
Is there fluid in the MC? How about the slave? Is it leaking?
Old 02-20-2010, 04:37 PM
mc was about half down when i checked it. ill check the slave in the morning as the 4runner is a long walk from my house
the mc has always had some fluid so i dont think air bubbles have formed in the hydraulic system.
Old 02-20-2010, 04:42 PM
4rnrlvr's Avatar
Have you tried to shift the transfer case?
Old 02-20-2010, 04:54 PM
transfer case shifts just fine, disengages the 4wd light, etc. just for the heck of it i unlocked the hubs and tried 2wd but same deal.
Old 02-20-2010, 04:58 PM
4rnrlvr's Avatar
My bet is there's a gear or shaft broke in the transfer case.
Old 02-20-2010, 05:19 PM
hmm, maybe time for a rebuild and duals =p.
im trying to stay positive... every broken thing is an excuse to spend money on fun stuff like more hardcore parts or more tools!
Old 02-20-2010, 05:31 PM
4rnrlvr's Avatar
OK. Hope it wasn't your DD.
Old 02-20-2010, 05:44 PM
nah, my DD is a 35ft El Dorado city bus :p. i drive a bus in boone.
anyone have anyway to rule out a tcase issue?
Old 02-20-2010, 05:50 PM
4rnrlvr's Avatar
Must be a Bitch finding a parking place at the grocery store.
Seriously though, it's a good thing you have public transit! When my transmission blew a couple years ago I found out the hard way how much it sucks to be broken down with no public transit, no extra set of wheels, and my significant other out of town. Be glad you can get around, cause sounds like the 4Runner might be grounded for a bit!
Old 02-21-2010, 06:09 AM
yup its a good though under appreciated system for sure.
anyone else think it could be the tc? it sounds feasible and i wouldnt know how to differentiate between te clutch going or the tcase going.
Old 02-23-2010, 08:39 AM
brian, i finally got down to check the slave. it still has fluid and is pushing the clutch fork as it should.
the transfer case is fine as well. apparently it is the clutch, i was just hoping it wasnt. yay for cheap advance auto clutches with lifetime warranties...
Old 02-23-2010, 08:47 AM
quasi's Avatar
sounds like you broke a driveshaft. do you have open diffs? try putting it in 4wd and see if it moves, or
jack it up and release the clutch to see if you have drive to the diffs.
good luck
Old 02-23-2010, 10:03 AM
i checked the drive shafts and transfer case. with the rear up on stands and in 2wd spinning the drives shaft spins the rears and in 4wd nothing spins since the front is still on the ground.
Old 02-23-2010, 11:04 AM
quasi's Avatar
ok, if the rear is up on stands release the clutch with the truck running. if the main driveshaft spins or not is what we need to know.
Old 02-24-2010, 06:32 AM
4rnrlvr's Avatar
Now that you added information to the original post, it does sound like it could be the clutch. Clarification about the idling would have been helpful the first time. But in low range it should still start to pull.
If it's not the clutch (I'm still not completely convinced it is) or driveshaft then the next most likely problem is transmission or between transmission and transfer case.
the1998sr5
15
07-14-2020 08:35 PM
PlayAwhile
07-20-2015 11:36 AM
1996Taco
07-20-2015 12:02 AM
the1998sr5
07-16-2015 06:20 AM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: 87 4runner- clutch, MC, etc problem?
