87 4runner cab?
Old 11-02-2009, 09:09 PM
WYOHillbilly's Avatar
87 4runner cab?
Hi Everyone, I'm new here, so be gentle.
I just picked up an 87 4runner. I would like to take the top off, remove the back seats and SEAL the cab off. Does anyone know of a company that sells something like this? If not, has anyone seen it done? I saw one on YouTube, but couldn't get ahold of the guy.
Yes, I should have just bought a truck, but this came available and thought it might provide more options down the road with the back seat.
So, basically, I would like a removable Cab shell.
Thanks in advance!
Old 11-02-2009, 09:25 PM
turboboost's Avatar
Yeah, it's called a pickup truck. Toyota has made this for years.
Old 11-02-2009, 09:27 PM
Gee...thanks for the help...couldn't have done it without you.
Old 11-02-2009, 09:28 PM
RMP8080's Avatar
do a search, a guy from the great white north did one, he has a build posting.
Old 11-02-2009, 09:29 PM
Thanks...any idea what the search would be? I've looked for about two weeks now and cant find what I want. Found some SOFT TOP type of things...but I want something with more structure. Back window and all.
Old 11-02-2009, 09:56 PM
eli-sky's Avatar
i like where you are going with that. im sure with some time you could make one of your own. does it need to be quick and easy to remove?. almost thinking something like a tonneau cover would be put on with. not velcro but it has a plastic lip on it that tucks under an edge. the possibles are endless! that is if you want to make your own
Old 11-02-2009, 09:58 PM
eli-sky's Avatar
didnt read last post. metal frame... pvc tube frame. i personally like the thought of pvc tubing as a frame
Old 11-02-2009, 10:00 PM
Well, I found the thread from the guy up north...like the concept...DON'T like chopping up my top!
YEARS ago a friend of mine had a 72 chev blazer...he took the top off...got a cab from a pick up truck and converted it to fit his blazer. Would it come off...yes, so IF he wanted to go back to the blazer he switched tops, put the back seat in and off he went. Did he do this often...NO, but it was an option.
The guy had a body shop...so it wasn't that big of deal for him.
This is what I want to do. will I go back often...probably not, but I could go back to sell if IF I wanted to.
Old 11-02-2009, 10:05 PM
peow130's Avatar
Go to a junkyard, fix a truck with a messed up front end.
Bring a wireless sawzall.
Cut the back part of the cab off, all the way down to the buttom.
Window and all.
Finish it your own way, reinforce the back, and seal it to the cab..
Old 11-03-2009, 06:25 AM
Junkers88's Avatar
Keep your eyes open for another fiberglass top. Then you could cut it and fab it in and stll have your original top.
Old 11-03-2009, 06:26 AM
Junkers88's Avatar
Window and all.
I like this idea better. It'd be neat as hell if you could find an extended cab and to this.
Road Bull
10-10-2015 04:55 PM
Nickdigg
07-07-2015 06:04 AM
bryan34w
07-06-2015 05:53 PM
Steezy96yota
07-06-2015 10:00 AM
elwood73
07-05-2015 07:07 AM
Quick Reply: 87 4runner cab?
