87 22Re timing
Old 11-15-2015, 06:18 AM
dmurrdub's Avatar
87 22Re timing
Took my 4Runner in for smog and didn't pass. Bought it year and a half ago through co worker, it passed to sell it. Have maybe 400 miles on it since. Told have vacuum line issues, timing @ 12 degrees not 5. My 1question is does a jumper wire need to be in place for correct timing?
Old 11-15-2015, 07:03 AM
dark_fairytales's Avatar
Yes, you need to use a jumper wire. By the way it is always possible that the smog tech did not jump it correctly. I have run into that in the past.
Old 11-15-2015, 12:17 PM
anndel's Avatar
The jumper is significant. When connected to TE1 and E1, the timing shows 5 deg BTDC. When removed, it shows 12 deg BTDC. Like Dark Fairytails mentioned, the tech either jumped the incorrect terminals or didn't do it at all.
SoCal_Todd
10-29-2015 05:52 PM
Obmi
09-16-2015 02:13 PM
87blyota
09-14-2015 08:38 PM
Alex Bessinger
09-03-2015 12:23 PM
insadj05
08-23-2015 09:11 PM
Quick Reply: 87 22Re timing
