87 22R power upgrades?
Old 10-25-2010, 07:34 PM
adeantoni's Avatar
Hey I recently (july) bought an 87 4x4 pickup with a 22R for $1350.00. It has 81, 000 original miles on it. I have had no problems with it till recenlty. Had some over heating problems which turned out to be the head gasket... Im bout to finish fixin that. But I was wondering what kind of power upgrades you would reccomend. I am now a freshman in college so money is kind of tight. so cheapish upgrades would be best. Also I want to put a small lift on this eventually, what lift and tire combo would you reccomend. I would like to try and stay close to the mpg im gettin right now (24-26 highway, 21 around the mountains by my house). Any suggestions would be great, thanks
Old 10-25-2010, 07:42 PM
DROPT's Avatar
definatley get a weber, possibly a cam and header too. but if you want to spend money get a built head as well.
or build a hybrid with a 22r block and a 20 r head
Old 10-25-2010, 07:43 PM
raddude666's Avatar
well honestly i wouldnt do a lift and tires and i have no idea what power upgrades because i took my 4 cyl out (22re) and put a 1uz in it i guess u could start with a small turbo tho get one off one of the old cryslers they work great and only run about 4 pounds of boost
Old 10-25-2010, 08:12 PM
adeantoni's Avatar
I plan to get a header and exhaust soon, hopefully by summer. What would the 20r head do for me? and also the weber carb? When I had the over heating problem I bought a new head. There was nothing wrong with the one I had but it needed a valve job, and it needed to be resurfaced so i bought one that was already redone with what i needed. it was the same cost. so I won't be buyin a new head soon, Im just wonderin what the 20r head would do for me.
Old 10-25-2010, 08:19 PM
DROPT's Avatar
the 20r head will give you higher compression but you can only use it on a pre 85 block
Old 10-26-2010, 11:33 AM
adeantoni's Avatar
oh ok. what type of header would be the best? I heard to stay away from pace setter headers. so im going to avoid those but what other types of headers would be reccomended? also i have seen 22R's with the chrome open style air filter. where could I find one? I haven't been able to find one yet. any suggestions?
Old 10-26-2010, 12:30 PM
DROPT's Avatar
get a doug thorley tri y header
Old 10-26-2010, 07:19 PM
adeantoni's Avatar
what are the benefits of the tri y header over the 4 into 1 collector?
Old 10-26-2010, 07:24 PM
xxxtreme22r's Avatar
low end power versus high end power
06-01-2021 01:51 PM
dumpster84
04-30-2016 06:03 AM
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
keithporter83
07-24-2015 07:37 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: 87 22R power upgrades?
