87 22R overheating issue!!!!
I have replaced the water pump all the hoses and the radiator cap and thermostat, When I drive it around town or on flat highways its fine but when I head up to where my folks live about 20 minutes up in the hills it gets way hot so i always have to stop and let it cool down, what could this be??????
no but I do believe there probably is a bubble in the system, I bought It off my friend and the day before I got it he put one in then the next day I got it I blew a hose, replaced all of them and thermostat. Do i wait to put the cap on once it starts bubbling over the top?
make sure your heater is on when you "burp" it. Placing the front on ramps helps. Squeezing the upper and lower rad hoses help as well. Since it wasn't overheating before you put the new water pump on then I would say it's just a bubble. Oh and while I think about it, people don't just on a whim change a water pump. Why was it changed?
no. it shouldn't bubble over too bad. if it does then you got other issues.
toyota has a "dual temp" thermostat, go to toyota and look up the part #'s. i dont know the exact number but there both the same part # except the dual temp part # ends in a 0 instead of an 8
Im guessing its the radiator, it looks pretty old, once I replace that and make sure to refill it with no bubbles in the system, if it still happens then I guess I will be on here for some advice
the1998sr5
15
07-14-2020 08:35 PM
Jeffreynmandy
07-18-2015 08:26 AM
the1998sr5
07-16-2015 06:20 AM
Avenged
07-09-2015 07:55 AM
