87 22R - Mixture Control Valve Tube ? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-08-2009, 12:07 PM   #1 (permalink)
hatda02's Avatar
Send a message via AIM to hatda02
After probably 8 years of owning my 87 I finally used one of the vacuum diagrams here on Yotatech to check routing of my lines. I did this because all of this time there was a hose hanging off my air filter box (not the right word) that I could not find a home for.
I found a couple lines were routed wrong (even though it has run and idled pretty well all of these years) and fixed those. The hose in question is the large one coming from the mixture control valve and should lead to a large hose connection from a threaded-in unit off the head. It has a couple other vacuum lines running out of it plus the large connection. Here is what I'm talking about (pic borrowed from another post here):
It is the connection to the right of the circled 2 in the pic.
The problem is, my truck does not have this connection. Where this connection is in the pic, it is a solid piece with no opening. I can upload a pic if needed.
I was told from the PO that the factory motor threw a rod and the motor was replaced from another Yota with a 22R.
So it runs pretty good and it has never been hooked up. Would you recommend I go to a junk yard and pick up the piece with the connection or can I live w/o it?
__________________
87 IFS Yota - Leaf/Torsion/Body Lift
99 4Runner Highlander
01 Viper GTS
02 Elantra
hatda02 is offline
Old 11-08-2009, 01:29 PM   #2 (permalink)
yoterr's Avatar
number one is the bowl vent, goes to charchole canister, and number 3 is for brake booster i think...and number 2....i dunno mines capped
__________________
new to me 86' toy on 35" procomp mud terrains, with a 4" lift and 3" body and palm fron camo for now...
04' Dodge 2500 4x4 QC hemi leveled, home made CAI and flowmaster exhaust
yoterr is offline
Old 11-08-2009, 05:55 PM   #3 (permalink)
hatda02's Avatar
I did not ask about those. I took the picture from somewhere else.
__________________
01 Viper GTS
02 Elantra
hatda02 is offline
Tags
22r, 86, control, mixture, pickup, toyota, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
