87 22r miss
Old 11-13-2014, 01:29 AM
Treybird_3's Avatar
87 22r miss
I have an 87 22r pu bought it needing a little work. So far I've added new plugs and wires new rod bearings crank was not scarred and platigauged within specs (not sure how well I trust it but the knock is no longer noticeable) with this it missed throught and would hardly idle. So I found a nearly new used carb cleaned it bolted on and now it's much better idles well on its on and drives very well. But still has a miss at idle its not predictable at all only really noticeable by listening to exhaust. Compression measures 120-135 on all 4 cyl. Im not sure about the vac lines. (Previous owner did a hack job on them) I put them back as they were and looked correct according to the poor diagrams I had to go by. ( minus the ones that look to be deleted by previous owner) dist and rotor look fine. Can anyone lead me to some other options I might look at? Or a good vac diagram.
icentropy
09-16-2020 02:47 PM
Sleaker
08-26-2020 06:03 AM
dumpster84
04-30-2016 06:03 AM
Koolbananass
08-12-2015 01:59 AM
TDonkey
07-26-2015 10:14 AM
Quick Reply: 87 22r miss
