87 1st gen Toyota help
Old 04-23-2011, 06:52 PM
JC_4x4's Avatar
Ok so I'm fairly new to 4runners and don't know a lick about em, but I have been having issues lately after I did a complete rebuild replacing Pistons, bearings, rings, and gaskets. Now it sounds like I am running rich and am sucking a lot of fuel. There are no leaks anywhere that I can tell, but I really am sucking so much fuel its ridiculous and I have a good stumbling/hesitation when I accelerate along with a lack of power. Could it be my fuel injectors? Fuel pressure regulator? Throttle Position sensor? I have no clue where exactly to start on diagnosing this thing and I don't want to just throw money at it. Any thoughts or how much more information do you need? Thanks!
Old 04-23-2011, 07:01 PM
markfagus's Avatar
Did you check, double check, and then triple check the timing?
Old 04-23-2011, 07:09 PM
JC_4x4's Avatar
I sure did! But I will recheck it again tomorrow and see if it stayed. I think the specs on the underside of my hood said 6 degrees from tdc and thats right where she's at. Should I try advancing it and then receding it a couple degrees and see if that makes any difference whatsoever?
Old 04-23-2011, 07:14 PM
85TurboRunner's Avatar
Did you jump the connector on the fenderwell when you did the timing?
Old 04-24-2011, 06:04 AM
JC_4x4's Avatar
I did that too, you jump 2 of the connectors in that little black box labeled diagnostic and that's supposed to reset the timing or something of that sort correct?
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
esun127
07-18-2002 07:53 PM
Quick Reply: 87 1st gen Toyota help
