'86 Turbo Toyota Transmission
Old 04-03-2010, 03:24 PM
ACZR's Avatar
Hello,
I have a 1986 Toyota pickup with the 22R-TE (turbo charged) and am wanting to swap in a 5 speed manual trans and I am wondering what transmission I will need and what model I would be able to get it out of. Thanks for your help.
Old 04-03-2010, 04:12 PM
'884Runner's Avatar
The 5 speed turbo models came from the factory w/ an r151 transmission, but a w56 will also work.
Old 12-13-2011, 05:25 PM
ducki1's Avatar
Trubo trans
Originally Posted by ACZR
Hello,
Once you have swapped trans...would you like to seel the automatic trans?
Paul
Old 12-13-2011, 05:31 PM
ducki1's Avatar
86 Turbo trans problems-NEED HELP!
I bought a 86 Turbo 4Runner, automatic, from a guy who ran the trans fluid out I replaced the fluid, filter and all three shift solinoids...does not run! Any suggestions as to what else I can look for/fix? Ban tightening?
What trans will fit the 22re motor that's in it now? I've read that a v6 trans will work, what years? Will all 4 cly auto trans work? Also read that a Jeep trans will work, what years model ?
Thanks,
Paul
Old 12-16-2011, 07:45 AM
skypilot's Avatar
Thanks,
Paul
Pump failure on the A/T will do that. It should at least pick the first gear / reverse clutch pack.
You need a w56 trans, flywheel, pilot bearing & clutch, along with second & third pedal w/ hydraulics.
Old 12-16-2011, 07:49 AM
Swimmerboy2112's Avatar
I have a turbo trans (R151) for sale out of an 86' pickup. Truck had 115K on it when pulled.
If you're interested, shoot me a PM.
Old 12-16-2011, 10:48 AM
ducki1's Avatar
Great. What are you asking for it? And where is it located?
Old 12-16-2011, 10:50 AM
Sending a PM
mskalmus
05-28-2017 07:51 AM
crashburnoveride
08-28-2015 09:20 PM
wilbertd
07-06-2015 07:39 AM
karbin
07-05-2015 11:37 PM
Quick Reply: '86 Turbo Toyota Transmission
