| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
86 turbo pickup turbo upgrade, now boost cut
#2 (permalink) |
does no one know any solutions to this? It only happens on heavy throttle, but on partial throttle, it does not do it very often
#3 (permalink) |
This is an old post but the 22RTE stock can only handle about 14psi boost before it shuts down. Sounds like you need an aftermarket fuel management system and possibly larger injectors.
__________________
Kristopher Erik "KD5EJO" Transplanted Alaskan in Foster OK 88 X-Cab now with 22RTE/93 FZJ80 Landcruiser w/e-lockers/"Work Truck" 00 Lexus LX470 FOR TOP NOTCH CARBURATOR OVERHAULS CLICK HERE http://www.yotatech.com/f37/ekhi-cus...turing-162085/ Like Fishing, hunting, Ham radio, flying, canoeing, kayaking, traveling, all the better with friends. Dedicated Christian. Excellent Wife. 3 Very Good Sons. Any other questions? |
#4 (permalink) | |
i was under the impression that the turbos only came in 4runners...
__________________
Trailer Re-Build - Check it out!!! Quote:
1990 4RUNNER
V6 & 5spd. | Custom Cat-Back | Magnaflow Muffler | ProComp Light bar | OME 901HD springs | Cobra 19 Ultra III Pro comp Driving Lights | 33x10.50 BFG A/Ts | 4.88 Factory Gears | Hi-Lift Jack |
#5 (permalink) |
There is really no safe way around fuel cut without going with a stand alone efi system. I would buy a boost controller and lower your boost to ten pounds max. You will most likely blow your motor up pushing more than that.
#6 (permalink) | |
Quote:
Agreed
__________________
1994 toyota 4x4. 22re turbo (sds em4, intercooler, steedspeed manifold, garrett t3) 4 inch procomp stage two lift front, t-bar crank(small), trail gear 4 inch rear lift with 6" shackles. ARB bull bar and warn winch, Quick lock rear, tru trac front 35x12.50 Pro-Comp Mud Terrains, 5.29 gears, snorkel, rock sliders Planned mods. , T-case gears, ditch ifs Beware the groove Man, its a shame when folks be throwin away a perfectly good white boy like that. |
#7 (permalink) | |
Quote:
#8 (permalink) | |
Quote:
Im under the impression you dont know your yota faq... /me ducks from thrown coil spring
__________________
Screw you guys I'm goin to TTORA |
#9 (permalink) | |
i cant throw my coils at you just yet ,scooby... my OME901s arent here yet...
![]() hmm... its funny... because before joining here, i never even knew about a factory option for turbo in toyotas... interesting...
__________________
1990 4RUNNER
#10 (permalink) | |
Quote:
a boost controller wont lower your boost any lower than the wastegate has it set. this is my first post on this forum, but i know a bit about turbo cars. how much boost are you running, do you have a boost gauge? A super 60 flows a whole lot more air than a ct20 does even if their at the same boost levels, ur injectors are probably having some trouble keeping up. source out some larger injectors, im sure there is something from another toyota vehicle that would work, (ive used n/a supra inj on a 5sfe celica). then pick up an apexi safc, to tune it. i bet it will take care of your issues, if not then look into upgraded maf options. |
#11 (permalink) |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
the fuel cut is caused by a couple of things all happening at once:
throttle opened to a wide angle and the air-flow meter reaching full-open. You don't get the cut at low-boost / part throttle because the AFM isn't saturated (maxed out on flow). at that point, the ecu has nothing to determine how much air is entering the engine and is also maxing out the duty cycle of the injectors so it cuts the injectors to lower the rpms and boost thus causing the afm to return to normal operation. One way to 'hack' around it is to tighten the spring in the afm, which causes the ECU to think there is less air getting into the engine thus shortening injector duration, and then installing higher flow injectors to add the extra fuel the ECU thinks it's cutting back on. The down side is that lower rpm operation will likely suffer from a rich mixture. Also, improperly chosen injectors or misadjusted afm can cause the ECU to not be able to adjust properly to the O2 sensor readings. |
#12 (permalink) |
Yea my bad on thinking a boost controller will open the wastegate sooner than what the wastegate is set at. Is the wastegate binding?
#13 (permalink) |
Too much air and not enough fuel = BOOM!
I am not sure how toyotas ECU works on there turbo cars, but every time I did some upgrade on my Subaru I had to get a tune. Intercooler, tune, injectors, tune, Turbo, tune. The tuner could usually just adjust my map. |
#14 (permalink) |
[quote=fivesfe;51028941]a boost controller wont lower your boost any lower than the wastegate has it set.
QUOTE] Doesnt that depend on the wastegate. I believe mine has that capability. There are two vac hook ups on mine. One above and one below the spring diaphram.
__________________
#15 (permalink) |
Was that "hack"a shot at me there Abecedarian? Just kididing.
#16 (permalink) | |
Quote:
hehe
#17 (permalink) | |
Quote:
Another interesting, but likely insignificant fact, the 22R-TE ECU actually cuts fuel at a specific airflow, not at a specific pressure. Saying it will cut at 14psi may hold true for the stock turbo, but with a bigger flowing turbo, boost cut could occur much lower, say 8psi. The best way to raise boost cut is to first install a larger AFM (Like from a 5M), then install proportionally larger injectors. This is done quite frequently in the Supra world, upgrading the 7M-GTE AFM with one from a 1UZ, then upgrading the 440cc injectors to 550cc. The problem is that you MUST make sure you are increasing each equally to ensure you don't run too lean. If in doubt, err on the side of larger injectors.
__________________
86 SR5 Turbo pickup Fiberglass bed, Fiberglass Fenders. 91 1.5JZ GT40 Supra. 77 Celica Liftback. (WTB: 20R Carb!) |
#18 (permalink) |
management or at least tune it. Your in CO and my buddy that lives in longmont builds megasquirt set ups. Foe now i think you trick the maf if you cant turn the boost down. you need to get it on a wideband and tinker for now tho.
__________________
87 longbed, 3rz, tacoma dash, bobbed, SAS'ed, gears and more. My build----HERE More web wheeling- Just getting started so come join us Asphaltsux |
| Tags |
| 86, accumulator, bigger, boost, en, engine, max, pick, pickup, subaru, torbo, toyota, turbo, upgrade, vacuum, wastegate, yota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| My Turbo manifold upgrade and sds | saitotiktmdog | 86-95 Trucks & 4Runners | 45 | 09-29-2009 12:01 AM |
| RPM vs Boost - turbo sizing | dcg9381 | 86-95 Trucks & 4Runners | 3 | 08-28-2007 05:20 PM |
| Turbo automatic transmission upgrade question | cchinny | Offroad Tech | 4 | 05-23-2007 06:24 AM |
| Turbo Boost! | fo_runner | Off Topic Talk | 10 | 05-18-2007 01:49 PM |
| 22r turbo upgrade? | kentucky_dan | 86-95 Trucks & 4Runners | 7 | 04-05-2007 07:28 PM |
