86 toyota pickup check engine light
Old 04-18-2014, 04:46 PM
hillbilly deluxe's Avatar
hey everyone, ive been having an issue with my 22re yota lately and I cant get it figured out. I get a cel at constant rpm and as soon as I accelerate, or decal it goes away. it doesn't store a code for me to get a starting point. its got newer plugs, wires, rotor, cap, air filter, o2 sensor. its also getting horrible mileage. around 10 to 13 mpg. does anyone have any idea where I should start? I drive 50 + miles a day for work as a firefighter and the mileage is killing me. any help would greatly be appreciated. I did a search and couldn't come up with much info.
Old 04-18-2014, 10:28 PM
Staff
Terrys87's Avatar
The most common issue I find when getting a check engine light and no code is vacuum leaks. Hoses are dried and cracked and let air in other places instead of thru the air supply like it should be.
The intake system can get clogged up with carbon from the EGR. Taking the Plenum off and giving it a good cleaning and all sensors and hoses would be a good start. I would also try the Sea Foam Treatment thru the brake line if it was me.
Old 04-19-2014, 06:40 AM
copy that. ill try and locate any vacuum leaks and do a good thorough cleaning. ya think the cel in closed loop is the reason for the crap mileage?
Old 04-21-2014, 09:41 AM
was able to pull the codes. code 5 which is 02 sensor code and code 12 which is knock sensor.
Alex Bessinger
06-28-2015 10:05 AM
94hiluxZE
06-22-2015 10:42 AM
paxanders
06-21-2015 06:29 AM
Mutinebullfrog
06-18-2015 01:36 PM
Dr. Evil
06-07-2002 09:19 AM
Quick Reply: 86 toyota pickup check engine light
