86 Runner ret swap finished um.... almost
Old 06-27-2010, 05:56 PM
JWillyG's Avatar
I bought my 86 Runner last year with 300,000 + miles on her.... no rust new everything, great starter. I purchased a 22ret with : wiring harness, cpu, and the digital dash and 110,000 miles! Should be simple, yet I have no plug in for the starter relay on the passengers side fender well, 15 plugs that go nowhere. I get nothing when I turn the key, so I bypassed and put a switch down to the starter, key on, cranking over and still no spark. so I have no spark plus no cranking hmm . Also the 7.5 fuse (drivers kick panel) has a short and pops the fuse, ignition fuse? The fuse box is also from the donor truck..
This is my main transportation so any input would be appreciated..
Old 06-27-2010, 08:11 PM
stackedyoda's Avatar
well if the 15 plugs went somewhere when the engine was in your donor truck, then i would think they need to be doing something in your runner. maybe try to find out where all the plugs went and try to find a home for them
Old 06-27-2010, 08:56 PM
JWillyG's Avatar
i have a 5 speed, the donor truck was an automatic, power windows, door locks, so I think alot of the extra plugs are for a tranny cpu plus all the other stuff. My runner is a trail rig so the only thing that is power is the rear window. Just lookin for the person who has done a swap like this...........anyone?
Old 06-27-2010, 08:57 PM
JWillyG's Avatar
Thats another thing , the fuel pump runs continuously, wont shut off while the key is on...........
Old 06-27-2010, 09:11 PM
JWillyG's Avatar
Ya the pump shouldn't run, spent hours trying to figure why.
No spark at all, everything on my runner works, drove her into the garage for the swap.
I had my son turn the key as if to start then I used my jumper to crank the starter still nothing.
Old 06-29-2010, 07:49 PM
JWillyG's Avatar
I downloaded a pdf with the wiring diagram for an 86 runner, trying to sort through it all today. I was really hoping for an easy swap!
Old 06-29-2010, 07:56 PM
JWillyG's Avatar
All fuses are good except a 7.5 amp ( ignition fuse) It blows as soon as the key turns on.
I have checked for any open wire leads and haven't located one yet. The wire harness was checked out a few times before I installed it. I need to find the neutral safety switch for the automatic, my tuck is a manual.
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
vasinvictor
01-20-2016 12:39 PM
thelifeadventure
07-02-2015 03:09 PM
TheManOutside
06-18-2015 03:32 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 86 Runner ret swap finished um.... almost
