86 Runner Budget Beefed up IFS
So my 4runner has a 3in body lift that the previous owner did and everything else suspension and steering wise is pretty much old and stock. Except I replaced the tie rod ends(oem) so it needs an aglignment. Its going to be sitting on 33x12.50s, it's on 31s atm steering is pretty sketchy. I plan to only spend like $300 max to beef my front end up to be able to handle the larger tires better. I was thinking about starting with a pro comp single steering stabilizer kit and upgrading to a hevier duty idler arm. I also need some shocks, probley just go pro comp as well. This sets me at $240. I want to know what you guys think and or would recomend. As well As to what i should spend the rest of my money on or if this would pretty much handle it? If you guys know better brand's or parts I should upgrade and replace let me know. All advice would be much apreciated
richdavies
01-18-2016 12:21 PM
Henrythewound
13
01-12-2016 07:18 PM
mapemberton12
01-10-2016 03:58 AM
