86 rear driveline
Old 10-04-2016, 06:58 PM
86sas'd's Avatar
86 rear driveline
Busy got the rear axle under my 86 standard cab shortbed and the driveline is about 5 inches to long what would the issue be? Is a 89 standard can shortbed driveline the same as the second gen one?
Old 10-04-2016, 11:45 PM
wyoming9's Avatar
Time to get a drive shaft made
Old 10-05-2016, 06:00 AM
muddpigg's Avatar
What's specs of rig??
Old 10-05-2016, 06:06 AM
86sas'd's Avatar
22r manual trans and single t case and 6 inch skyjacker rear springs
Old 10-05-2016, 06:30 AM
muddpigg's Avatar
If I were you I'd make sure front drive shaft will work with that height prior to changing rear.
Old 10-05-2016, 11:52 AM
osv
osv's Avatar
did the springs get changed along with the axle? i'm wondering if the axle got moved forward... you could try measuring the wheelbase.
you are going to go with what you got, so that probably doesn't matter, just get the driveshaft shortened and balanced.
is the rear axle rotated up? you'll probably need a dual cardan joint in the rear driveshaft.
Old 10-05-2016, 12:30 PM
muddpigg's Avatar
Do you have springs orientated correctly??
Old 10-05-2016, 12:38 PM
86sas'd's Avatar
Yes short side forward right?
Old 10-05-2016, 03:41 PM
muddpigg's Avatar
IDK, never used skyjacker. But being 5" long when should be a little short. Call manufacturers tech support.
Barnes 4wd
Vendor Advertising
16
11-17-2016 10:22 AM
msane99
10-01-2016 12:22 PM
muddpigg
09-20-2016 05:22 AM
68jimmy
08-21-2016 05:17 PM
Rory Jackson
08-01-2016 04:02 PM
Quick Reply: 86 rear driveline
