86 pickup smog failed, please help. Did not pass NO
Old 09-20-2010, 07:50 AM
raiders42673's Avatar
I have a 86 toyota pickup that failed smog the NO's were way to high. What could it be? Engine is 22r.
Old 09-20-2010, 07:59 AM
tgergen's Avatar
High NO is usually caused by excessive heat during combustion/lean condition.
I would try to retard the timing a bit. Also, make sure your thermostat is working correctly and coolant is topped off, etc, etc.
You can also "tweak" the airbox meter (or carb) a bit to richen it up.
Old 09-20-2010, 08:03 AM
4Crawler's Avatar
EGR as well, make sure it is working perfectly and that all the ports/passages are totally clean and flowing well.
Might help to post what engine you have.
icentropy
09-16-2020 02:47 PM
Colington
03-08-2020 09:51 AM
God's Bounty Hunter
07-08-2015 12:54 PM
timmJ
07-07-2015 02:01 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 86 pickup smog failed, please help. Did not pass NO
