86 pickup no spark
Old 10-14-2013, 08:00 PM
timtoyo's Avatar
Exclamation 86 pickup no spark
so i was driving and my truck died, figured out the timing chain had jumped and towed it home and did a new timing chain and water pump, still didnt run. redid the timing chain and still nothing only to find out im not getting spark. where do i start checking? replaced the ignition coil about a year ago so what else should i check before just wasting money and replacing stuff? i need this done!
Old 10-15-2013, 06:32 PM
RAD4Runner's Avatar
Originally Posted by timtoyo
... where do i start checking?...
To start, got power to ignition circuit?
Check if you have 12V on Black wire with red stripe (B-R) enclosed in yellow in pic below:
How sure are you that you used good ignition coil?
No spark out of ignition coil (before distributor) or no spark to spark plug?
Checked resistance of your high-voltage ignition wires?
Check resistance of signal generator (pickup coil)? 140-180 ohms
Many more to check...
Old 10-16-2013, 11:50 PM
timtoyo's Avatar
I couldn't get a spark out of the old coil (got a new one) if I tested it properly. New coil and distributor cap 12v in ign coil.
sandyota
02-04-2021 11:16 AM
Eggslinger
06-08-2019 03:32 PM
smiley52
07-11-2015 05:16 AM
88runnergomas
07-09-2015 01:12 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 86 pickup no spark
