86 pickup hesitation
Old 11-03-2010, 03:30 PM
ssteve's Avatar
I have a 86 4x4 pickup thats stock and its giving me some issues. It has a slight hesitation at part and moderate throttle. Its not a hesitation like its cutting out, but feels as if its pulling a whole bunch of timing or something and just real sluggish. I have only had the truck a few months and it had a ton more power before, but now is sluggish and when I first take off the check engine light comes on. Just changed the plugs, wires, cap and rotor and it seems to be a bit better but did not solve the issue. Whats next?
Old 11-03-2010, 03:32 PM
xxxtreme22r's Avatar
do a search for the way to read the check engine code as that will most likely point you and us in the right direction on how to fix the issue.
Old 11-03-2010, 05:13 PM
mikes451's Avatar
If it has a carburator might need to adjust idle mixture, that fixed my hesitation. I just drilled out plug and adjusted for highest RPM.
Old 11-03-2010, 05:31 PM
I don't believe the carb'd trucks had CEL's. At least mine doesn't. Maybe the cali spec ones were different?
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: 86 pickup hesitation
