86 pickup auto transmission problem
Old 01-19-2015, 09:35 AM
EastTNyota's Avatar
Exclamation 86 pickup auto transmission problem
I have a 1986 pickup the transmission shifts fine till it gets to 3rd then catches 4th almost instantly, fluids are good, solenoid is good.. it has push button O/D and with it off it still kicks into overdrive.. any ideas of what it may be ??
Old 01-19-2015, 12:48 PM
bswarm's Avatar
Switch, wiring, OD solenoid, OD solenoid o-ring bad or missing.
Old 01-19-2015, 02:02 PM
EastTNyota's Avatar
All of that is good, I talked to guy earlier today he had mentioned the 3rd gear friction plate, any ideas on that ??
Old 01-19-2015, 05:40 PM
bswarm's Avatar
Kickdown linkage adjusted ok? From here you'll have to go into the valve body and see if anythings amiss. Those are like brain surgery, lots of springs, check valves, etc. so if you go into it yourself get a breakaway diagram.
Old 01-19-2015, 06:42 PM
EastTNyota's Avatar
"Bswarm" Yeah kickdown is good and tight.. Where can I find a breakaway diagram, cause that's my next step I reckon..
Old 01-19-2015, 06:48 PM
bswarm's Avatar
You'll need the trans model, then Google for the valvebody diagram. How many miles on the trans? If over 100k might as well get it rebuilt.
Old 01-19-2015, 06:52 PM
EastTNyota's Avatar
It's got around 200k, so you recommend on rebuilding it?
Old 01-19-2015, 07:12 PM
bswarm's Avatar
It's up to you, that's a lot of miles. It is something fun to learn if you want to tackle all or part of it. There's specialty tools needed for compressing the clutch packs and pulling them out for a rebuild. Usually trans rebuilds only require new seals and o-rings, the hard parts including the friction discs hardly ever need replacement.
Old 01-19-2015, 07:16 PM
EastTNyota's Avatar
Ok I may just get a rebuild kit and go from there, I believe my trans is a "A340F" can you help me confirm that?
Old 01-19-2015, 08:14 PM
bswarm's Avatar
Here's how to decode the vin plate...
http://www.4crawler.com/4x4/ToyVIN.shtml
It should be accurate as long as somebody didn't replace the trans with something else.
Old 01-19-2015, 08:52 PM
EastTNyota's Avatar
Awesome thanks for help!!
Old 01-27-2015, 12:17 PM
EastTNyota's Avatar
NEED HELP!! PLEASE
solenoids are good ,new brake pack.. Trans still hits third for a split second then shifts into O/D and has no power.. Any clues???
vasinvictor
01-20-2016 12:39 PM
94whiterunner
09-22-2015 07:25 PM
Dillon1983
07-07-2015 06:47 PM
bigblue82
10
07-06-2015 08:27 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
Quick Reply: 86 pickup auto transmission problem
