86 pick head liner remove
Old 09-06-2009, 07:41 PM
Jay1's Avatar
I need to remove my head liner so i can cut the roof for a sun roof. Is their any special way to remove it?
Old 09-06-2009, 07:55 PM
Jay351's Avatar
What kind? Can you feel a peice of wood or anything behind the material, or is it just material?
Old 09-06-2009, 08:21 PM
sh0kk86's Avatar
its just a piece of vinyl with pockets sewn into it for the metal "bows" to go through.
unless you know how to take out your rear window your most likely going to ruin the headliner.
Old 09-06-2009, 09:26 PM
Jay1's Avatar
So if i get the back window out the head liner will come out?
Old 09-07-2009, 08:39 AM
samiam39's Avatar
why would you want a sunroof, I have had them in many of my trucks and would never put one in. hell even in so cal where it rarely rains they always end up leaking, so up north where you live yikes. hope you don't mind leaks.
Old 09-07-2009, 09:40 AM
peapicker's Avatar
remove the back window, there is some adheisive on the edges of the headliner under the rubber trim on the door opening. Be very very careful pulling the edges off or you will tear the headliner. Pull out the intierior lite and sun visors, and that is about it if I rememberd all of it. There are 2 or3 meatle braces in the headliner that you will pull down in the middle to get them out of the pockets on the edges.
someone help him out if im forgeting anything
Old 09-07-2009, 10:46 AM
Jay1's Avatar
The reason i want a sun roof is because it can be very hot in the summer. My little windows dont help. When it gets to 110 out side you dont drive vehicles with bad air flow.
Old 09-07-2009, 03:31 PM
turborich's Avatar
110 in the summer, well with that sunroof that 110 degrees is going to be burning on your head unless you tint it pretty dark. most of the factory sunroofs will have a coating on them to keep the heat from burning you up.
You don't have A/C? Try making one of those ice chest A/C coolers!
http://www.youtube.com/watch?v=xRXCdy05bJs
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
luckypig44
07-19-2015 11:25 AM
Quick Reply: 86 pick head liner remove
