86 p/u 22r te won't rev over 2,000 rpm
HELP! I have replaced and adjusted everything on this truck. short of the block,pistons and crank. it has new ECM, fuel pump,injectors, TPS, AFM, PCV, pressure reg., pluse valve, fuel filter, head,head gasket, vaccum lines, ex. manifold, distirbutor,cap,wires, plugs, rotor...you name it I have replaced it. and still,it will not run over 2,000 rpm. I've even had a shop try to fix it .they could not figure it out. Only thing that helps is if I put a cap full of fuel, carb. cleaner or anything else right in the throttle body. And then it will rev up a few times till it uses the extra fuel up then back to under 2,000 rpm. i have even tried blowing the fuel lines out. someone please tell me what is wrong with this little truck! I have completely restored it ! looks great. but I can't drive the thing!Oh yeah! this maybe important, the truck sat for about seven years without running it had fresh motor and tranny. I bought a new Harley and just kinda quit driving it..
I have checked for leaks. I have loosened the tail pipe just ahead of the cc. I do have a small ex manifold leak. and the timing well i can't see the crank other than the pully mark and when i try to time it it wont run at 5 degress btd. it want to be advanced . I tried moving the cam gear one tooth eather way but really could till.
I have spent many a hour looking for a leak or something that would keep it from drawing enough air through theAFM to make the ECM give it more fuel. If I turn thr throttle and the AFM needle atthe same time by hand it will rev up.
Man, I am so damn close and I can't get passed this! i am almost sure it just isn't getting enough fuel. but for the life of me I can't figure out why. everything I try ... I'm out of ideas. i've had this little truck forever and would rather have and drive it as a new one.
Check your fuel pressure, and check your fuel filter. You may also have varnish in the fuel rail or something that is preventing the injectors from saturating.
did you check to see if there was anything under the gas pedal? lol just kidding. hmm when did this problem arise? does it idle low or struggle to start? give us more symptoms. what does it sound like? does it shake and vibrate? have you double checked throttle linkage? we need more info.. maybe try doing a compression test.
it hasn't ran right sense it sat for so long. Ive poared sea foam, injector cleaner through the rail , blown air through the rail. it seemed to ran a little better afterward but goes right back to only rev to 2,000 rpm.if my timing is off (advanced about 7 degress) do I move the cam sprocket clockwise or counter clockwise to correct it? the motor starts fine, idles smooth revs up to 2,000 rpm and then its like theres not enough fuel. it starts missing, bogging down. and if you back off the throttle to around 2,000 it smooths out again.it has brand new fuel filter and ive run about 50 gals. of berrymans through it.
i'm a motorcycle mach. by trade, so i have a little savey about what gas does to a fuel system. and i really feel thats where the problem is. maybe replace all fuel lines? I'll make up a fuel pressure gauge to hook up to the cold start injector and let you know whats up there...
It appears you have a severe lean fuel problem. Fuel pressure at the engine should be checked first. If good then it could be fuel volume delivery issue. Fuel pump or crap in the tank is suspect then, inspect every inch of the hard fuel lines for kinks, REPLACE EVERY INCH OF RUBBER HOSE FROM TANK TO EFI FUEL RAIL. They have been known to swell from the inside and restrict fuel flow. Obviously fuel filter is suspect and should be pulled and cut open to look for junk from the tank. Inside of tank could be full of RUST since it sat for so many years. I think you will find your problem following these suggestions. Finally, get a mechanic to set your ignition timing.
i was working on a truck and could not get it to run correctly and it came down to the new, actually rebuilt, injectors. Evidently the ball inside the injector can get stuck and cause a problem like you are having. To solve this a mechanic told me to take the injectors back out and to tap them against a piece of wood to free the ball inside. Just be careful not to tap too hard and brake the end off.
Howdy Ed. I had the similar problem with my 86 turbo toy, i had some new parts on it, including a famuos tps, well that was the problem. I had it wrong, the best/easy way to find out if that's the prob. just disconect the wires. hope this helps you.
I also have seen (not done myself) a mis-installed TPS. Apparently my buddy can rebuild his 22re from scratch, but he can't properly install a TPS I jumped right to the TPS, unplugged it, and it would rev! I pulled it off and re-seated it with everything aligned right inside, and the problem was no more it was a new TPS he installed incorrecetly by the way.
