86 a/c rebuild
86 a/c rebuild
Before I tackle my a/c systemm just wanting to know what common failures, loose connections, corroded wire, bad switches are issues in these older trucks. Don't have experience with a/c systems but this will be my daily driver so any advice is appreciated.
The first thing you really need to do is look over the system is it still closed??
Has it been open to the air the last few years??
Pull a vacuum it sucks to get it all fixed up only to find the evap coil is full of holes
This is the part in the heater box that can bring one real joy if your a hardcore masochist
It pretty much all comes down to how you were taught in HVAC
Pretty much test for leaks
then repair leaks
charge system
trouble shoot electrical side repair as needed
then repair leaks
charge system
