'86-'92 Toyota Supra AFM
Is this the year you can use on a 22RE?
I've heard a rumor that its a popular mod for more airflow, and I figured Id ask since I just spotted this on craigslist
http://spokane.craigslist.org/pts/860546631.html
I know this is going to sound stupid but does the valve cover or something say 5M-GE? If no then how do you know what engine is in the Supra?
ok so
86.5 to 92 is a 7m-ge or the 7m-gte ( T for turbo )
and the 5m is from the supra celica model before it
i dont know wich fit your model as i have a 3vze but if you would like to brush up on your supra knoledge go here
http://www.supramania.com/
Don't get stuck on just finding a supra, the cressida's were the flag ship models and they all had the 5mge motors steal the box and the Maf out of them. The throats are way big as well
oh man its easy it took me like 10 min for real. and its way better and cheaper then the LCE intake kit. i have the LCE version on my 2wd
A 7M-GE versionI believe works with an electronics swap, much like the later 5M-GE ones. I think it's the same size as teh 5M ones though.
A 7M-GTE one will NOT work. It's a completely different style of AFM.
i know, im ressurecting an old thread. but myyota, did you ever get it installed? and if so, how did you mount it up? i know its plug and play, i had one but sold it to a member on here, and will soon be buying it back. my problem with it was i couldnt get it mounted properly, due to not having the bottom piece for it. how did you correct that?
I mounted mine on both rigs using some all-thread and bolts as uprights. Mounted them in place of the battery once the swap was made with the battery and factory air box. It's a little ugly but it works.
i know, im ressurecting an old thread. but myyota, did you ever get it installed? and if so, how did you mount it up? i know its A and play, i had one but sold it to a member on here, and will soon be buying it back. my problem with it was i couldnt get it mounted properly, due to not having the bottom piece for it. how did you correct that?
09-04-2015 09:27 AM
