86-89 wiring hardness
both 22're engines from the 86/89 use the same wiring hardness correct? everything from the tail lights to the air meter up front.. the 86 looks like a wiring night mare but all the lights work,signals etc. it also seems to need both leaf springs,ifs replaced. rotors, brakes,and wheels are rusted. steering rods creak, pitman arm is rusted * if i had a sand blaster i'd do the whole truck.
No they are not the same.
85-87
88
89-95
These are the correct year splits. (Someone correct me if I am wrong)
I believe the biggest difference are the fuel injector connections. I know 88 is the odd ball year that has it's own unique conector.
85-87
88
89-95
haha check this out. since i wanna switch engines and what not, decided to decode the vin.
4/86
Truck
22re
auto
longbed
std cab
what it should be is a 4/86 22re , 5sp, Dlx cad somebody did a whole lotta switching out on this thing.
4/86
Truck
22re
auto
longbed
std cab
86 and 89 are NOT interchangeable, different injectors (and thus plugs), AFM is different, knock sensor might be different, ECU is different etc etc.
Yet another reason why I love my 22r carb truck.
djpg2000
11-11-2020 04:56 AM
skoti89
07-08-2015 12:05 AM
