86 4runner verses tree Front wheel pushed back
Old 01-29-2013, 06:29 AM
Bigal389's Avatar
I'll try to keep this as short as possible so bear with me. This is my first experience with Toyotas so pardon the ignorance. I restored an 86 4runner auto for my son, it's what he wanted for a graduation present. It has a freshly rebuilt 22re, Zuk mod for the sagging rear, 31/10.50/15 Kenda Klevers, Rhino lined interior and top. Now for the bad, my son and some of his friends were playing in some trails and he hung a tree with the passengers side front tire breaking the shaft out of the steering box. We replaced the steering box and pitman arm, the rest of the suspension appears to be undamaged. The passengers front wheel is pushed back 1", I haven't been able to find anything that is bent or broken. Is this a common problem when hitting some with a front wheel or does anyone have any ideas on a fix for this?
Thanks, Al
Old 01-29-2013, 06:36 AM
Buck87's Avatar
We love pictures.
Old 01-29-2013, 06:38 AM
Bigal389's Avatar
I'll try to get them later.
Old 01-29-2013, 06:49 AM
MudHippy's Avatar
Very common. Because most folks don't add the additional brace/truss between the LCAs(at the rearward LCA mounting brackets). Then, when you hit something with one of the front wheels, the frame rail gets pushed/bent inwards. So, in all likleyhood, you have a bent frame at this point. Unless you're one of the very very few of us that have installed a brace/truss to prevent it....
Old 01-29-2013, 06:59 AM
Bigal389's Avatar
I have not installed any additional bracing, so please tell me what needs bracing or support to prevent future issues. Can you explain this brace/truss and how/where it is installed? Also what is the best way to fix this?
Thanks, Al
Old 01-29-2013, 07:06 AM
Marc's Avatar
A frame shop can fix it for sure.
You might try and find a place that does front end work on big rigs as well as smaller trucks.
Some of them can straighten out minor stuff easily.
Old 01-29-2013, 07:10 AM
MudHippy's Avatar
What I'm talking about is described in full detail by the link below:
http://www.sonoransteel.com/index.ph...products_id=25
As stated, the best way to fix it would be to have it straightened by a frame repair shop.
But, I managed to fix mine well enough buy other means...
Old 01-29-2013, 07:49 AM
Bigal389's Avatar
Give a little more detail on the home repair!!! Looks like something I did with a bronco years ago.
Old 01-29-2013, 08:44 AM
yotasavg's Avatar
Mudhippy that is very cleaver! I like that a lot, and some of your hippy friends can do their slacklining at the same time!
Old 01-30-2013, 04:45 AM
Bigal389's Avatar
Pics didn't work. I'll retry again
Old 01-30-2013, 07:26 AM
MudHippy's Avatar
From another thread...
Originally Posted by MudHippy
The strap on the driver's side was looped around the frame rail just to the rear of the UCA and connected to itself with a shackle I put in the loop at it's end. I made sure it wasn't going to pinch on the torsion bar under load by feeding the end of the strap under it and then around the frame rail before putting the shackle on to form the loop there. Then I turned the steering wheel all the way to the left so I could get the clearance needed to get a straight pull on the other frame rail with the chain without it pushing forward on the passenger side tire. Attaching the chain to that frame rail was a little more tricky because there's also some brake lines that run along top of it where I wanted to put it. I fed the hook on the end of the chain under those and under the torsion bar so it wouldn't pinch them when I pulled, and then used the hook to form a loop in the chain around the frame rail. Again I put the loop as close as I could get it to the UCA. I didn't worry too much about the fuel lines running along the inside of the frame rail there, because I figured the chain would be applying the most tension at the top and bottom corners of the frame rail. That proved to be the case, and those lines were unharmed in the process. After rigging it all up and attaching the come-along, I just pulled and pulled and pulled some more. I pulled on it 'till I thought I couldn't possibly pull it any tighter.
Then I took a breather. After which, to verify I'd given it everything I had, I tried one last tug. I got another click or two more tension on the chain, then felt/heard three rather loud pops coming from my lower back. No questions asked that was definitely as hard as I was going to be tugging on anything that day. And I regretted having taken it to that extreme for a couple good reasons. First because my back was aching something fierce at that point. Second, and if you've ever used a come-along you should already know this, it wasn't going to be easy to release the tension on the line. You see the harder you pull on those things, the harder you have to pull to get the release mechanism to activate. I knew this, but thought I still had it under control, and could figure out a way to do so.
And I eventually did. It took some carefully coordinated pushing, instead of pulling, on the handle. Or I would've had to cut the strap, and being the penny-pincher that I am, that wasn't gonna happen unless there was absolutely no other alternative.
Old 01-30-2013, 09:23 AM
Buck87's Avatar
A friend installed a home made IFS brace on my rig. We had to use a porta power to spread the frame apart wide enough to fit the brace in. It is now back to it where it is supposed to be and so much stronger. Mine is welded in. The bolt on option looks good also.
Old 01-30-2013, 10:11 AM
Bigal389's Avatar
I think I'm going to try Mudhippy's route on the frame then build a truss for it myself this weekend. I'll post the results and pics if I can get them to load. From the link Mudhippy's posted it looks pretty straight forward.
Al
Old 01-30-2013, 11:11 AM
Bigal389's Avatar
Drivers side front wheel, the oil bottle fits loosely:
Pass. side front wheel, about an inch and a half differance:
Steering box and Pitman arm:
All within a 1/4 mile of entering the trail.
Thanks, Al
Old 01-30-2013, 01:15 PM
Buck87's Avatar
I hope this is helpful.
[IMG][/IMG][IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
When I installed mine I used a hydraulic porta power and spread the frame rails until they were back to normal. Should be easy and cheap to rent for a few hours if you prefab the brace first.
Old 01-30-2013, 07:05 PM
Bigal389's Avatar
That's a huge help, thanks for showing the measurements as well. It helps a lot getting material together.
Thanks, Al
voiddweller
19
05-02-2016 09:10 PM
YotaGreenhorn
06-27-2015 07:00 AM
Niameyrider
06-25-2015 05:50 AM
WI Girl
06-25-2015 03:45 AM
Quick Reply: 86 4runner verses tree Front wheel pushed back
