86 4runner smoking/possible rings, valve seals?
Old 02-18-2014, 03:01 PM
jarheadtex's Avatar
Its been a while since I have been to the oracle ...but I have an issue with my 86 4runner 22re..if you are bored and have a minute i would appreciate your opinions..
I have had this truck about a year...not one issue. However, every once in awhile on start up it will run on less than 4 cylinders ..you know it feels like a clogged injector or bad plug wire. It it only does it a short time. As soon as I start driving it fires on all 4 and feels fine. Well it did this today, but when it kicked up and started running like normal it started smoking like crazy. It was constant for a while. I turned around and went back to work to park it...thinking head gasket. I got in to go home, fired it up and ....no smoke. So I thought it was maybe a valve seal or ring. Then it returned on the way home. On decel, it was smoking quite a bit but by the time I got home it stopped.
I get home and checked compression, #1 130 #2 150 #3 165 #4 170. I also checked the valve clearance and #1 intake was a little lose but the rest were good.
Im thinking valve seal or rings. What do you guys think? I would mind if it was a ring honestly I wouldnt mind rebuilding it with a little more balls.
Old 02-18-2014, 03:29 PM
Sturmcrow's Avatar
Did you try the trick of putting a bit of oil in each cylinder and testing compression again? If it goes up, rings, if not, valves.
A leak-down test can tell you even more information about where the leak is.
Bad news though is that I think your numbers are super low. Isn't the standard for the 22RE 190 PSI?
Old 02-18-2014, 03:53 PM
jarheadtex's Avatar
I did not try that yet. I just messed with it for a bit after work. It is bad news I am afraid....I may be rebuilding. It is odd though, how it goes progressively up from #1 to #4
Old 02-18-2014, 06:50 PM
RJR
RJR's Avatar
Nominal is 171, min is 142, difference should be <14 (that's for a '94)
Old 02-19-2014, 01:50 PM
jarheadtex's Avatar
I screwed up when I did the test anyway. I did not depress the throttle. I have to get new plug wires tomorrow, as I ripped two of them off in the process.
Old 02-20-2014, 03:50 PM
jarheadtex's Avatar
I fired it back up today. It was definitely burning coolant. I also checked the compression again and it was 180/180/185/180. So, head gasket it is. I ordered a kit from engnbldr along with the 268 cam to install while Im in there.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
Gamble_STi
07-07-2015 07:54 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 86 4runner smoking/possible rings, valve seals?
