86 4runner shifting problems.
Old 12-25-2009, 01:05 PM
ethanp123's Avatar
recently my 4runner has been acting up and not wanting to shift. The first few shifts are fine but then the last shift doesn't always go, so the rpms just shoot up and turn the motor harder when on the gas. Also occasionally there is a high pitched screach when accelerating and not shifting, any help wood be appreciated its an 1986 4runner, with an automatic tranny.
Old 12-28-2009, 12:35 PM
colsoncj's Avatar
how does the fluid look? it sounds like your clutches/bands are worn for OD.
Old 12-28-2009, 01:20 PM
ethanp123's Avatar
i have changed the fluid and filter, and now is fine thanks for the help.
Old 12-28-2009, 03:44 PM
abecedarian's Avatar
You might be able to adjust the detent cable (goes from the throttle to the transmission) and get the pressure up in the trans and get it to shift but more than likely the trans is on its way out.
The screech is probably a v-belt slipping.
Old 12-28-2009, 04:40 PM
Bigblock's Avatar
Or a bearing starving for oil!
BigBlock
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
crashburnoveride
07-10-2015 06:39 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: 86 4runner shifting problems.
