'86 4Runner automatic shifts WAY too early
Old 12-06-2010, 02:18 PM
Utah4Runner86's Avatar
Hi all. First post (but I've been lurking a bit, love the site). Couple days ago, the trans (an A340 of some sort, I don't know which one) in my '86 went haywire. As I accelerate from a stop, it shifts up from 1st to OD in about three or four seconds(shift shift shift, that fast), and it won't downshift from OD once it's there, even with the pedal through the floor. I can't tell for sure, but I don't think it comes back to 1 until I come to a stop. It doesn't appear to be slipping, and it moves easily through all gears when I manually select them with the shifter. Trans fluid is full.
I have a copy of the FSM, but I don't recognize this set of symptoms in the troubleshooting guide, and transmissions in general are black magic to me. This trans is new to me, I picked it up last spring on the cheap and I don't know its mileage or history. It's worked great until now.
Any ideas?
Old 12-06-2010, 03:17 PM
4runnerx3's Avatar
What size tires?
Old 12-06-2010, 07:18 PM
Originally Posted by 4runnerx3
What size tires?
31x10.5, why?
Old 12-07-2010, 02:53 PM
4runnerx3's Avatar
Does it do it in the power mode?
Old 12-07-2010, 06:27 PM
Yah. I don't have a tach, so I can't be sure, but it doesn't appear to make a difference whether I'm in power or normal mode.
Old 12-07-2010, 06:42 PM
R.DesJardin's Avatar
Issues
Likely culprits, the TPS or the VSS. Check all your electric connections first. You can search and find the test procedure for the TPS, the VSS I'm not sure of the test protocol since it sends out a signal not a voltage.
Old 12-22-2010, 10:36 AM
Sorry for the late response. You nailed it, bad connector on the TPS. Thanks for the direction, I would not have thought to go there. Thanks!
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
crashburnoveride
07-10-2015 06:39 AM
shar
07-09-2015 12:38 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: '86 4Runner automatic shifts WAY too early
