86 4runner Air Valve help/diagnosis - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-16-2007, 08:07 PM   #1 (permalink)
SoCal4Running's Avatar
Had the truck overheat because of a rusted out freeze plug, upon disassembly of the motor noticed a little bit of oil/water sludge in the Throttle Body. Found out that the sludge got to the throttle body by way of the Air Valve hose. Is it possible that whatever separates the coolant from the air inside the Air Valve has ruptured? There is no oil/water mix under the oil filler cap. The engine is a 22re.
__________________
'86 4runner
22RE, 5-speed, LC Street EFI head w/ cam, LC Pistons, ARP Head Studs, Downey header, Dynomax 2 1/4" full exhaust, VDO water temp guage, 01-03 Tacoma cd\tape radio with 10" Bazzoka, Downey 2" rear springs, GDI radiator, Torus fan DONE!!!!
'68 Ford Mustang Fastback
Daily driver with a built 289 and a streetfighter trans.(Retired)
98 Subaru Outback-Took over daily driving duties
MicroMatic.com
Waco93.com
SoCal4Running is offline
Old 01-17-2007, 08:26 AM   #2 (permalink)
InternetRoadkill's Avatar
The auxillary air valve has no coolent lines running to it. It's electric. The throttle body does have coolant lines however. I would suspect that the coolant in the air valve came from a leak in the throttle body.
InternetRoadkill is offline
Old 01-17-2007, 04:21 PM   #3 (permalink)
Thanks will investigate the issue further.
__________________
'86 4runner
MicroMatic.com
Waco93.com
Old 01-17-2007, 07:18 PM   #4 (permalink)
I dont know when I was pulling the ac pump and the harmonic ballancer I took a closer look a the air valve and it has an electrical plug at the rear of it and two coolant hoses then the big hoses in the front which are obviously for air.
Stole this from another site: Mentioned the coolant lines in the last 2 sentences.
The problem is most likely in the air valve or the hoses that route the
bypassed air around the throttle body. Check the hoses to make sure they
are still attached and/or not broken or cracked. Check the resistance of
the heater coil resistance of the air valve at the connector (should be
around 38-60 ohms). With the engine warm, restrict the airflow through
the valve by pinching off one of the hoses. The idle speed should not
drop more than 50 rpm. You can even remove the valve and inspect it
visually. Cold, you should be able to see through the hose passages.
With the valve warm, the passage should be closed. I have used a heat
gun or hair dryer on the coil portion of the valve to check this.
Removal of the valve is simple, just a bolt or two, the air hoses, and a
few coolant hoses. Some coolant will leak out, so be prepared to catch
it. Clean up any spilled coolant, animals love it (except my dogs, they
have "shop experience").
Now I'm really confused
__________________
'86 4runner
MicroMatic.com
Waco93.com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Burned valve diagnosis alankenji_84 86-95 Trucks & 4Runners 14 01-22-2007 08:22 PM
Air Pocket in Coolant Lines/Air Valve Adjustment sleestak240 86-95 Trucks & 4Runners 0 07-23-2006 05:11 PM
Air valve? red 59 95.5-2004 Tacomas & 96-2002 4Runners 6 07-27-2004 10:33 AM
Air Valve? HammerDown6 95.5-2004 Tacomas & 96-2002 4Runners 5 08-19-2003 12:14 PM
AS air suction valve muddyboots 95.5-2004 Tacomas & 96-2002 4Runners 2 07-25-2003 10:04 AM
2009 InternetBrands, Inc.
