| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
86 22rtec turbo . rebuliding turbo help!!
#2 (permalink) | |
Quote:
http://22rte-trucks.com A backyard rebuild of your CT20 is really only possible before the turbo fails and some will say that it's not possible without the right equipment to balance it. Best case: you pull turbo, disassemble the turbine and compressor - you need to mark the orientation of the compressor on the turbine shaft as these pieces are dyamically balanced. Clean everything up, check for shaft wear and clearance, install new bearings/seals, put it back together. Things to watch out for are overtorquing the compressor nut, excessive wear on the bearings, seals, or backing plates, and proper orientation. You can buy rebuild "kits" from places like the gpop shop. If it "needs" a rebuild due to not making boost, don't waste your money on parts - it needs to go to a shop to be checked out. Expect to pay $300 for a proper rebuild, new seals, new bearings, balance and reassemble. The other option is to ditch the CT20 and go Garrett or CT26.
__________________
http://www.22REturbo.net |
| Tags |
| 22rtec, ct20, parts, turbo |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 87 Turbo 4Runner: Rebuild Tips/ Parts/ Turbo | boost-hungry | 84-85 Trucks & 4Runners | 0 | 10-07-2007 10:53 PM |
| Latest turbo incarnation 22re turbo | dcg9381 | 86-95 Trucks & 4Runners | 8 | 07-26-2007 05:43 AM |
| Turbo vs Non-turbo Timing cover | Bill | 86-95 Trucks & 4Runners | 6 | 03-19-2007 02:00 PM |
| WTB: Stock turbo parts ex mani, turbo | soarerjzz30 | The Classifieds GraveYard | 3 | 01-18-2007 05:13 AM |
