86 22ret wont stay running. please help!
bought a 2wd 86 extra cab turbo truck for 400. wouldnt start. bad pump. replaced the pump and cleaned tank (truck sat for 5 years VERY bad gas) checked fuel filter wasnt plugged or nasty but i replaced it any ways now it only starts for about a second. its only starting off of the cold start injector, if i un plug it it wont start. what are the chances of all four injectors being completely pluged from bad gas? whats the best way to check for power to the injectors? thanks in advanced.
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
tap on the injectors...
Take a socket extension and just tap on them... Try light at 1st but more than likely you'll have to tap on them harder...
lol, dont you love the little extra the turbo does for these trucks? i was actually passing people on the highway up hill in 5th when i bought mine, then i put 33s on it now i just keep up with people up hill in 5th at 6psi lmao
glad its running for you, did you check compression? mine are all 120-130, just wondering what yours are with that many miles
kawazx636
10-06-2021 03:03 PM
