86 22re vs 88 22re
86 22re vs 88 22re
Maybe i complicated things with my last post. Does anyone know what systems/parts are on an 88 22re that an 86 22re doesn't have?
Emissions equipment are different....pretty sure. 88' EGR has an electronic VSV as opposed to a thermal vac valve. Plus, everything routed a bit differently. Breather lines on the '86 go to the plenum while on the '88 some go to the intake tube. There's another emission part the '88 has that '86 doesn't. Can't think of what it's called offhand, though.
The '88 TB design is different. It has a couple more vac ports the '86 doesn't have. Plus, the '88 has a thermal wax/non electrical auxiliary air/idle control valve while the '86 has an electrically heated unit....power supplied by the opening circuit relay. The '86 also has a temp switch (for the AAV, I believe) mounted on the thermostat housing....and, the '88 doesn't.
As a result, the ECU's may be a bit different. Not sure, but plausible, though. You'd need to verify.
The AFM's are a bit different because of the additional emissions stuff. I believe it's the PAIR reed valve I'm thinking of.???
Uhm.....that's all I can think of, at the moment.
