'86 22RE problems-blown coolant
okay guys, gotta call from an old friend last night and he said his toyota 22RE blew up...well i figured it had a bad knock and a rod through the block..that's my idea of blown up.
well i get there..coolant is everywhere..the radiator cap blew off? and it will turn over just fine, but will not fire?
anybody got any ideas from that little bit of info? i'm doing a compression test on it real soon because he said it turns over like it has no compression but he's not a very bright kid LOL
truck has quite a few miles on it..somewhere around 250,000 or so..it's his daily driver..
so i'm gonna try to help a friend out, if not then i'll prolly sell him my '80 for cheap just to get him by.
Possibly head gasket, even though I don't think the 22R is known for that.
If you have a coolant system pressure tester, test the system and cap and see if it holds pressure. If it does, refill with water (for now) or coolant and maybe replace the cap, depending on how it tested and how old it is.
Of course, checking the compression is next, like you're going to do.
Anything past that is purely a guess until more information becomes available.
yea i thought just the cap blew off...no...the whole neck the cap is screwed to blew off....i cranked the truck and it sounds like no compression..i'm gonna pop the valve cover and check the timing chain..wish me luck guys i won't be doing it until sunday though..i'll update monday!
the1998sr5
15
07-14-2020 08:35 PM
Tacoma1313
08-17-2015 05:44 PM
itzmywife's
07-25-2015 04:55 PM
