83 toyota axle or 1-ton military axles
Old 06-15-2007, 08:42 AM
offroad4x4yota's Avatar
I been lookin into a sas for my truck and the more I research the more I lean to the 1-ton axles. I think I would save money in the end by putting the 1-ton axles under the truck because I wouldn't have to regear it right away, plus the axles would be about unbreakable. Where as with the toyota axle I would have to replace the axles with longfields and regear it. Then on top of it all you cant beat the way a toyota truck looks with full size axle under it. It just gives it this mean look. The big benefit is that I can get the wheels tires and axles for less than $1000. I know the driveshafts would have to be reworked but the truck is getting twin t-cases anyway so either way the driveshaft work was goin to happen. Just wanted to get some input from everyone. Maybe there is an issue I havent thought of yet.
Old 06-15-2007, 08:59 AM
dijlop's Avatar
well shoot, if u think thats what u want id say go for it. they sure can look mean. kinda buff. lol. sounds like u got a pretty good deal on the axles wheels and tires there.
Sponsor
Tofer's Avatar
the 83 yoter axle will be easier to install, less fab work.
the 1-ton should be stronger but will require more custom fab. to get them to work right.
Old 06-15-2007, 09:05 AM
WFO
WFO's Avatar
You have to upgrade your brake master clylinder to push the bigger brakes. But its not that hard.
You can buy the brakets for the full width swap. I think SKY makes them. Or just build your own.
If you can get your axles wheels and tires for $1000. Do it!
The following users liked this post:
Backfire420 (03-08-2022)
Old 06-15-2007, 09:07 AM
most of the fab work was going to have to be done anyway for what all i was doing so either way I am getting into the same amount of fab work.
Old 06-15-2007, 09:08 AM
dijlop's Avatar
precisely. thats when u ask urself, why not? and get on it. just make sure u post pics. lol.
Old 06-15-2007, 09:16 AM
I have a build up thread on here currently https://www.yotatech.com/forums/f116/start-new-project-86-pickup-115741/
So if you want to see it as it comes along take a look. Its going to slow down for a little while because I got to pay some bills first. Then when I am debt free my truck will be moving along very fast!
Old 06-15-2007, 09:17 AM
Thanks I didnt think about the brakes. Ill be getting a whole truck when I get the axles so I can get the master cylinder off of it.
Old 06-15-2007, 09:36 AM
The wheels and tires come off of a hmvee (think I got that right). I can get used ones for very cheap, and the tread is not even half way worn and some look brand new. They are 37" goodyear mtr's II
Old 06-15-2007, 09:44 AM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
sheesh, you walked into some real deals! whos your supplier, or arent you talking?
Old 06-15-2007, 09:46 AM
Ill say after I get mine. LOL dont want no one to get them before I do.
Old 06-15-2007, 09:47 AM
Ill make sure and do a big post on where to get them But I am affaid if I say now everybody is goin to flood it and I wont be able to get it for the low cost I can now.
Old 06-15-2007, 10:19 AM
Stomis's Avatar
Hmmmm Humvee tires you say? Are they 16.5 rim? Does the sidewall actually saying Goodyear MTR II or does it read Goodyear RTII OZ? I have these
http://cgi.ebay.com/ebaymotors/4-NEW...spagenameZWDVW
and they are some pretty beefy tires but are 36x12.5 r16.5. Got 4 new for 350 shipped. I know that right now the military uses 37x12.5 Goodyear MTR's.
Old 06-15-2007, 10:21 AM
waskillywabbit's Avatar
The toy axle is much lighter and has better ground clearance.
A few upgrades and the toy axle is just as strong and much stronger on a weight to strength ratio.
You will have less issues staying with the toy axle IMO.
And mine looks better than full width anyway.
Old 06-15-2007, 11:29 AM
AxleIke's Avatar
Full width is neat. Glad you are doing this rather than a crappy stock toy set up. I like keeping things toyota personally, but if you've got a good deal, don't pass it up.
Get it done!
Old 07-13-2007, 09:56 AM
I am going with dana 60's stuffed with 7.17 on 44's. I figured if I go with big axles I better just go on and go with big tires. The truck is going to be designed to be an all around truck. Some times we go mud riding and other times rock crawling or a little of both, so I want to have a rig that is able to conquer both.
Old 07-13-2007, 10:03 AM
CJM
CJM's Avatar
I hope your truck has enough power to push those meats and axles. Your gonna need a chevy V8 in there sooner than later.
Old 07-13-2007, 10:33 AM
95RunnerSR5's Avatar
it shouldn't be to bad with 7.17's should it?
Old 07-13-2007, 11:36 AM
chimmike's Avatar
+1, those axles are probably more than twice as heavy as stock yota axles, plus the huge unspring weight of the wheels and tires....that thing will be a DOG.
IMO, yota axles are the way to go. There's really no justification for doing what you're talking about doing.....
Colington
03-08-2020 09:51 AM
crashburnoveride
08-28-2015 09:20 PM
ItsJustD
07-07-2015 07:49 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: 83 toyota axle or 1-ton military axles
